check engine rought idle , help
Old Jul 14, 2012 | 12:50 PM
louie007's Avatar
louie007 is infamous around these parts
This morning i went to start the car 2006 c4s and i had a rought idle like the car was going to die then the check engine light came on turned the car off started again same thing , car drives fine only when its at idle it does that no power lost while im driving it , any help would be great before i take it in on Monday , thanks
Old Jul 14, 2012 | 02:47 PM
bbywu's Avatar
What engine code did it throw?
Old Jul 14, 2012 | 03:04 PM
cerbomark's Avatar
cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !
FYI, I started mine the other day with the oil cap not properly seated and it ran like that....
Old Jul 14, 2012 | 07:48 PM
louie007's Avatar
Problem solved , removed MAF sensor cleaned it maf cleaner put back in waited about 15 min idles like it should .
Old Jul 14, 2012 | 07:51 PM
MBENZF1's Avatar
MBENZF1 has much to be proud ofMBENZF1 has much to be proud ofMBENZF1 has much to be proud ofMBENZF1 has much to be proud ofMBENZF1 has much to be proud ofMBENZF1 has much to be proud ofMBENZF1 has much to be proud ofMBENZF1 has much to be proud ofMBENZF1 has much to be proud of
These fricken things are so finicky.
Did you do anything to the car? Top it off with oil recently? Spirited driving? Driving in rain?
How many miles?
Edit: just noticed you solved it.
tropicatango
Jun 8, 2025 01:00 PM
Mini George
Jul 29, 2019 12:20 PM
Mini George
Jan 18, 2016 09:16 PM
