Will these wheels fit my narrow bodies 997? Offset question...
Old Jul 26, 2012 | 02:07 PM
mickfluff's Avatar
mickfluff has a brilliant futuremickfluff has a brilliant futuremickfluff has a brilliant futuremickfluff has a brilliant futuremickfluff has a brilliant futuremickfluff has a brilliant futuremickfluff has a brilliant futuremickfluff has a brilliant futuremickfluff has a brilliant futuremickfluff has a brilliant futuremickfluff has a brilliant future
SIZE : FRONT 19X8.5 REAR 19X11
PART # : FRONT 99736215605 REAR 99736216202
OFFSET: FRONT ET 56 REAR ET 51
I am OK with spacers if needed but these came off a 997TT I believe... I am pretty sure they fit, its the offset I am not 100% sure on,
Thanks all for the help...
Old Jul 26, 2012 | 03:14 PM
slicky rick's Avatar
slicky rick is a glorious beacon of lightslicky rick is a glorious beacon of lightslicky rick is a glorious beacon of lightslicky rick is a glorious beacon of lightslicky rick is a glorious beacon of lightslicky rick is a glorious beacon of light
Fronts will surely fit. Its the rear that you might not like the look of. Oem offset is at 67 so it like putting in a 16mm spacer at the back
Old Jul 26, 2012 | 03:25 PM
///MJFDDS's Avatar
///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute
They will fit. I ran the same width wheels in et 51 front 55 rear with 5mm spacers on my lowered 997S with no issues. You may want a spacer in the front to even out the stance, but you will not need one in the rear.
Old Jul 26, 2012 | 03:33 PM
mickfluff's Avatar
thanks
from what I gathered they should fit.... unless anyone knows for sure different?
Just did some more research...
mickfluff's Avatar
thanks all
thanks all...
Old Jul 29, 2012 | 08:39 AM
Johnny DB's Avatar
I've got those on my car. They fit fine and I also put 5mm spacers in the rear and 7mm in the front.
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 18, 2015 03:42 PM
PelicanParts.com
997 Turbo Vendor Classifieds
Aug 18, 2015 03:41 PM
PelicanParts.com
997 Vendor Classifieds
Aug 18, 2015 03:39 PM
