Porsche Stroker Engine
Old Aug 18, 2012 | 11:11 PM
VM997C4S's Avatar
VM997C4S is infamous around these parts
Are there any stoker engines out there for any Porsche models?
Old Aug 18, 2012 | 11:20 PM
tunedgoody's Avatar
tunedgoody is a glorious beacon of lighttunedgoody is a glorious beacon of lighttunedgoody is a glorious beacon of lighttunedgoody is a glorious beacon of lighttunedgoody is a glorious beacon of lighttunedgoody is a glorious beacon of light
LN engineering sell a bore kit and you just need to find good tuner and good advance mechanic.
you can go to 4.2L
Old Aug 19, 2012 | 03:28 PM
lacrosse's Avatar
lacrosse has much to be proud oflacrosse has much to be proud oflacrosse has much to be proud oflacrosse has much to be proud oflacrosse has much to be proud oflacrosse has much to be proud oflacrosse has much to be proud oflacrosse has much to be proud oflacrosse has much to be proud of
I believe a stroker engine uses a modified crankshaft to allow for greater piston travel. A bore kit will make the engine "over square".
Old Aug 19, 2012 | 05:13 PM
Hella-Buggin''s Avatar
Hella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud of
Correct, you are increasing the stroke of the crankshaft.
Some extremes even require the case and rods to be shaved to allow clearance.
I once had a vw beetle with a crank that was stroked from a stock 69mm to 82mm.
This provided tons of low end torque.
joseph_number1
Jul 19, 2018 05:45 PM
Jun 10, 2017 07:45 PM
Aug 20, 2015 12:17 PM
