Coolant Leak
Old Sep 24, 2012 | 01:16 PM
Luckymba's Avatar
Luckymba is infamous around these parts
Coolant Leak
So I noticed my coolant was down a bit. Bought some pink stuff and a new cap (just in case of evaporation) and filled it up. Went for a spirited 80 mile drive this weekend and came back and checked it. I threw a white sheet of paper down underneath what looked like the leak area. Sure enough I had a silver dollar sized pink spot on the paper after an hour - so it isn't a fast leak by any means. I guess my question is what am I looking at in the way of repair costs? Is this something that will get worse as I go or can I nurse it with more pink stuff when it hits the min? I appreciate the help.
Old Sep 24, 2012 | 01:39 PM
David9962000's Avatar
David9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond repute
It might be a hose, clamp, water pump or the reservoir. Have it checked out.
Old Sep 24, 2012 | 01:54 PM
Dadio's Avatar
Dadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond repute
Where exactly is the leak ? Under the engine, left, center, right.... etc ? Or one of the front radiators ?
Old Sep 24, 2012 | 01:58 PM
Luckymba's Avatar
It is about 12 inches in from the rear driver's side wheel. Directly in line with the coolant reservior to the rear but further forward.
Old Sep 24, 2012 | 02:27 PM
Dadio's Avatar
Makes sense that the coolant tank or the cap could be the issue. Cap would show same color residue at the cap and in the area where the cap attaches. There is drain hose exiting the area just under the cap which could eventually end up where you're seeing the leak. If not there than would check the bottom and sides of the coolant tank for dampness or residue.
Old Sep 24, 2012 | 05:15 PM
cerbomark's Avatar
cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !
Fix the leak!!!! Don t just do the top it off method. It will get worse no matter what.
Old Sep 24, 2012 | 07:03 PM
marlon 997's Avatar
marlon 997 is infamous around these parts
I had a cracked coolant reservoir a couple of months ago. Same symptoms. About $500 to replace it.
Glasgo
Nov 30, 2015 02:37 PM
freddiemac
Oct 7, 2015 11:05 AM
flewis763
Oct 4, 2015 04:14 PM
