Oil Pressure Gage Question
Old Oct 22, 2012 | 08:29 AM
luigi007's Avatar
luigi007 is infamous around these parts
Can someone tell me if it is normal to have the gage all the way up to 5 at idle speed when engine oil and water temp is up to temp (water temp-175 / oil temp-200). I have seen it drop around 2-3, but sometimes is all the way up to 5. Is this normal?
Old Oct 22, 2012 | 09:49 AM
cerbomark's Avatar
cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !
997.1 or 997.2? Seems high.
ECS Tuning - Porsche's Avatar
I don't think the oil pressure gauge should read that high when the oil is fully warmed-up. There is probably something wrong with the gauge cluster or your oil pressure sending unit.
Old Oct 22, 2012 | 10:38 AM
luigi007's Avatar
997.1. MY 2005. I agree. The problem is that sometimes it reads between 2-3, but some other times it reads all the way up at 5. Not sure why?
Old Oct 22, 2012 | 10:43 AM
luigi007's Avatar
The problem is that sometimes the gage reads between 2-3 and some other times reads 5. Gage going bad? Maybe the module?
Old Oct 22, 2012 | 11:42 AM
Alan C.'s Avatar
Alan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond repute
I've had a similar problem in the past and it traced back to a bad ground.
Old Oct 23, 2012 | 11:26 PM
Hatzenbach's Avatar
Hatzenbach has a spectacular aura aboutHatzenbach has a spectacular aura about
Could be that the cable on the oil pressure sender is starting to get loose
Old Oct 24, 2012 | 01:38 PM
Hella-Buggin''s Avatar
Hella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud of
I've had this happen occasionally when I'm on the high side of the oil level. Once the temp era a little hotter it should drop.
Old Oct 24, 2012 | 04:05 PM
Tarek307's Avatar
Tarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond repute
Most of the time mine is always at 5, very rare have I ever seen it fluctuate or be normal
Old Oct 25, 2012 | 09:48 PM
911CT's Avatar
911CT is infamous around these parts
I've noticed that mine is doing the same lately... Just watching it for now...
Old Oct 26, 2012 | 07:08 PM
Dadio's Avatar
Dadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond repute
Mine has never read 5 at idle so I suspect the gauge or sending unit or whatever is going bad. Not sure if it would throw a code but would be worth checking.
Old Oct 27, 2012 | 10:58 AM
Tcc1999's Avatar
Tcc1999 is a splendid one to beholdTcc1999 is a splendid one to beholdTcc1999 is a splendid one to beholdTcc1999 is a splendid one to beholdTcc1999 is a splendid one to beholdTcc1999 is a splendid one to behold
As a data point for you, my previous '08 C2S almost always ran around 5 and sometimes, at idle, around 3-ish. It was never a problem and Porsche Techs were unconcerned (whatever that is worth). I'm not stating this as a fact because I read it elsewhere on the topic of oil pressures in the 997.1 v. 997.2 (any corrections appreciated as my memory may not be that great) but there is one oil pump in the 997.1 so the pressure will run high because the it is always "on". In the 997.2, which I currently have the pressure seldom ever gets above 3. It was also in something that I read that this is due to the fact that in the DFI engines, oil pressures are managed differently (more than 1 pump I think?). I don't know if any of this is correct but it would be nice to hear from people who know more facts than I do.
Old Oct 28, 2012 | 11:43 PM
Franky Knuckles's Avatar
Franky Knuckles is infamous around these parts
Mine typically reads high as well at 5 or just below. Can someone clarify the differences in 997.1, 997.2, etc? What does the number after the decimal represent? I have an 07 Carrera...what would that be?
Old Oct 28, 2012 | 11:55 PM
soccerTOOLsu's Avatar
soccerTOOLsu is infamous around these parts
Mine is almost always at 5. It was a concern for me but read that is the norm.
Old Oct 28, 2012 | 11:57 PM
997.1 is from 2005- 2008.
997.2 is from 2009-2012
The .2 models have a DFI engine with increased power and the loss of the controversial IMS. Also, improvements in the PCM and PASM systems. I'm sure someone can chime in and explain in more detail but that's a quick breakdown.
