Loss of power during spin/ fishtail
Old Apr 14, 2013 | 07:31 PM
SlateC2S's Avatar
SlateC2S is a glorious beacon of lightSlateC2S is a glorious beacon of lightSlateC2S is a glorious beacon of lightSlateC2S is a glorious beacon of lightSlateC2S is a glorious beacon of light
2005 Carrera 997 S
Today after AutoX I stayed in the empty lot and decided to mess around a bit. It was raining and the lot was wet and slick so I wanted to push limits and learn something.
I had sport suspension engaged and PSM off.
I noticed that on hard acceleration during a turn when the rear began to hang out I lost power. I began to do it purposefully to figure out what was going on. I noticed that when the rear really started to swing out and I hammered the accelerator - trying to purposefully counter the fish tail with adding power - that the car dropped the revs. It was almost as if there was some safety feature kicking in that was not allowing me to add power during a spin. Note that I had the PSM OFF. I cannot understand why I could not power my way out of the spin - it just would not let me. It was not a fluke because I was able to consistently replicate it. It almost FELT like there was not enough fuel getting the engine during the spin. I was hammering the gas and it just would not respond almost like it wanted to stall but it was not that bad.
Is there some safety/fail-safe feature that I don't know about or do I perhaps have an issue.
Now here is a little tid-bit that may or may not be related. A month ago I was also on the AutoX track and I noticed a few times that also during hard cornering the car hesitated (sometimes a couple of times) when I hammered the gas out of a turn. It FELT like a burp or brief stall or flood. It was suggested that I may have a crappy batch of gas (?Quicktrip?). This did NOT happen again on the track today (Chevron) - so I thought that I had solved the problem. Again - i have no idea if these issues are related but I thought it may be a clue.
Any suggestions or advice would be greatly appreciated.
Old Apr 14, 2013 | 08:00 PM
kouzman's Avatar
kouzman has a brilliant futurekouzman has a brilliant futurekouzman has a brilliant futurekouzman has a brilliant futurekouzman has a brilliant futurekouzman has a brilliant futurekouzman has a brilliant futurekouzman has a brilliant futurekouzman has a brilliant futurekouzman has a brilliant futurekouzman has a brilliant future
i have read that even if you turn the PSM OFF the car still has some level of intervention. What you are describing i have felt with PSM On. i never turn it off even when i Autox... I stil manage to be in the top ten fastest cars even in Raw Time not just PAX...
Old Apr 15, 2013 | 09:44 AM
Tito_gsx's Avatar
Tito_gsx is infamous around these parts
slate, I'm a bit puzzled with your problem. I just finished a wet autox last weekend and had no issues with nannies kicking with psm off. My car was a joy to drive, was very predictable sliding on entry and exit...got 3rd fastest time of day on my 888's. I remember reading a old thread where someone had similar issue to you (doing trackdays), try doing a search. I'll let you know if I find it but I suspect its electronic issue.
Old Apr 15, 2013 | 11:07 AM
spiffyjiff's Avatar
spiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud of
if the oil pressure shoots down drastically, as it would most likely in a spin, in a non-dry sump, do the nannies cut the power?? when i did a 180 spin at VIR last year i could have SWORN i had "both feet in" but car conked out anyway. (things happened so fast, i dont really know for sure if car conked or my left foot wasnt fast enough.)
Old Apr 15, 2013 | 03:58 PM
SlateC2S's Avatar
Interesting....it DID conk out during one significant spin...and since I was purposefully initiating the spin...I KNOW 100% I had my clutch in - I thought at the time that maybe i had not jammed it in fast enough - but in retrospect maybe it is related?!?
Old Apr 17, 2013 | 12:24 AM
SlateC2S's Avatar
Just to be clear - there was no braking (on my part) during the spin. On the contrary, I was trying to bring the car back into line with throttle.
I am disappointed by what I am understanding from other forum posts about PSM still lurking in the background when in OFF mode and kicks in under extreme circumstances. I just find it hard to believe that Porsche has restricted the ability to completely turn off stability management.
I found these videos on youtube of 997's drifting nicely. I was NOT able to throttle through the slide AT ALL like these video show. As soon as the car significantly kicked out, throttle was cut back- which is great....if I wanted a babysitter.
Some possible suggestions include: faulty PSM, oil pressure drop (faulty), fuel pressure drop. Still waiting for some solid technical facts.
http://www.streetfire.net/video/porsche-997-gt3-donutburnout_2083611.htm
Old Apr 17, 2013 | 07:13 PM
SlateC2S's Avatar
speed bump!
Appreciate the input so far.
Can anyone provide some really solid technical facts and/or info?
COBB Tuning
Mar 29, 2016 09:26 PM
Ferrari
Aug 24, 2015 04:35 PM
