Common Problem Areas in 997.1
Old Apr 22, 2013 | 08:54 PM
fastm3's Avatar
fastm3 is infamous around these parts
Angry Common Problem Areas in 997.1
The Porsche 997 has a reputation as a reasonably reliable car, at least by sports car standards. I've now had my car for about 9 months, and have spent about $2000 on various repairs, most recently cracked coils which seem to be a common problem area. I'm wondering what other issues are common to these cars, as well as the approximate repair costs, assuming the Porsche dealer does the work.
I'm not interested in the very rare kind of issues, but the common, well known, or catastrophic ones.
These are the ones I personally know of:
- The dreaded IMS failure. Rare, at least after 2005, but certainly catastrophic. Cost: Unknown (New Engine)
- Cracked coils - $1200 for a new set of 6
- RMS - $800 to $1600 for replacement depending on model
- Coolant Expansion Tank - $400 to $500 for replacement
- Water Pump - Cost?
What else gentlemen....?
Old Apr 22, 2013 | 09:52 PM
Jam996's Avatar
Jam996 has much to be proud ofJam996 has much to be proud ofJam996 has much to be proud ofJam996 has much to be proud ofJam996 has much to be proud ofJam996 has much to be proud ofJam996 has much to be proud ofJam996 has much to be proud ofJam996 has much to be proud of
Battery cable from alternator is a common problem 100$-300$
Old Apr 22, 2013 | 10:01 PM
carrera997re's Avatar
carrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant future
Jam i replaced mine at the dealer payed close to 900 lot of labor sooo the dealer said.
Old Apr 22, 2013 | 10:19 PM
fastm3's Avatar
Yeah, I think $100 to $300 is just for the part, isn't it? From what I've heard, the labor is pretty involved.
Guys, I'm asking about costs for parts+labor, assuming the work is done at the Porsche dealer, not DIY or Indy.
Old Apr 23, 2013 | 04:26 AM
AP1to911's Avatar
AP1to911 is just really niceAP1to911 is just really niceAP1to911 is just really niceAP1to911 is just really nice
Shifter cable.
not a cheap fix, and a very common problem.. mine snapped at 40k
i think around $700(?) to fix. don't quite remember too well
Old Apr 23, 2013 | 10:53 AM
v35's Avatar
v35
v35 has a reputation beyond reputev35 has a reputation beyond reputev35 has a reputation beyond reputev35 has a reputation beyond reputev35 has a reputation beyond reputev35 has a reputation beyond reputev35 has a reputation beyond reputev35 has a reputation beyond reputev35 has a reputation beyond reputev35 has a reputation beyond reputev35 has a reputation beyond repute
Air Oil Separator- AOS. Around $800-900
Old Apr 23, 2013 | 12:21 PM
gloves's Avatar
gloves has much to be proud ofgloves has much to be proud ofgloves has much to be proud ofgloves has much to be proud ofgloves has much to be proud ofgloves has much to be proud ofgloves has much to be proud ofgloves has much to be proud ofgloves has much to be proud of
The starter cable cost me $715 (parts and labor) from a dealer.
I also had a Charcoal Filter problem and a Fuel Strainer problem...but both were covered when I was CPO. As well as a bad Coil Pack.
Old Apr 23, 2013 | 12:52 PM
Dadio's Avatar
Dadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond repute
Battery cable cost $ 98.00
Coil packs - about $ 200 for 6 but only the cracked ones need replacing
AOS - $ 125
Shifter cable set- $ 200 to $ 250
Labor will vary but all of these parts can be replaced as a DIY projects. Some are more difficult than others but with the exception of a $ 25 cable alignment tool for the cables, none require any special tools to complete. If you don't care to do do it yourself knowing a competent Porsche repair shop can save you significant $$'s. None of these parts have failed on my 2007 C4S.
Old Apr 23, 2013 | 11:59 PM
Izzycab's Avatar
Izzycab has a spectacular aura aboutIzzycab has a spectacular aura about
Where can I get the AOS for $125? I might just do mine now, I am not having any issues, but do you suggest I do it?
Old Apr 24, 2013 | 10:37 AM
Dadio's Avatar
I'd try Suncoast or Sunset Porsche but I wouldn't replace it unless it was broken or you had other reasons to do the install that required the removal of similar parts to gain access. Replacing the alternator-to-starter battery cable for example.
Old Nov 25, 2014 | 09:52 AM
SoCal997's Avatar
SoCal997 is infamous around these parts
Last night I noticed a check engine light after hitting a pothole and a few minutes later...a huge plume of white smoke coming from the exhaust. The car was towed to the shop on a flatbed this morning and was quickly diagnosed with an oil separator issue. This shop stocks this part so it is a very common issue especially with the age of my car (2007, 997.1, 65K miles). Apparently, the engine needs to be dropped to replace the oil separator for tiptronic cars.
Old Nov 25, 2014 | 12:39 PM
Ynot's Avatar
Ynot Is a GOD !Ynot Is a GOD !Ynot Is a GOD !Ynot Is a GOD !Ynot Is a GOD !Ynot Is a GOD !Ynot Is a GOD !Ynot Is a GOD !Ynot Is a GOD !Ynot Is a GOD !Ynot Is a GOD !
RMS leak - $1,200 fix under warranty
Worn tie rods - at 23K miles, fixed at Indy $800 for both inner and outer tie rods, dealer quoted $1,300 for just the inner tie rod.
Besides that, car is reliable.
drapersa70
Jan 19, 2016 10:01 PM
MrNurse
Sep 10, 2015 09:44 AM
fredz
New Member Introductions
Sep 3, 2015 10:17 AM
gulf gt
Aug 27, 2015 10:27 AM
