LED replacement for the Headlight 5W Bulb
Old May 8, 2013 | 02:02 PM
Arielao's Avatar
Arielao is infamous around these parts
Post LED replacement for the Headlight 5W Bulb
Hello,
I replaced the regular 5W bulb from the headlight with an LED and the sensor thinks there is no bulb, is there any solution besides installing a resistor?
Old May 8, 2013 | 07:46 PM
wc11's Avatar
wc11 has a spectacular aura aboutwc11 has a spectacular aura about
Originally Posted by Arielao
Hello,
Car needs to see a "load" of some type.
Old May 8, 2013 | 08:21 PM
K-E-V's Avatar
K-E-V Is a GOD !K-E-V Is a GOD !K-E-V Is a GOD !K-E-V Is a GOD !K-E-V Is a GOD !K-E-V Is a GOD !K-E-V Is a GOD !K-E-V Is a GOD !K-E-V Is a GOD !K-E-V Is a GOD !K-E-V Is a GOD !
Do you mean the W5W type bulb? You can get one that has a built in load equalizer and that will prevent your car from throwing a code.
Old May 9, 2013 | 06:07 AM
jhbrennan's Avatar
Hello,
Which bulb did you replace?
Bulb chart
Low beam Philips D2S 35W
Additional high beam without cornering light H11 55W
Additional high beam with cornering light H7 LL 55W
Turn signal indicator light, side WY5W
If it was the WY5W - you might check with these guys:
http://www.hoen-usa.com/city.htm
Old May 9, 2013 | 09:35 AM
Arielao's Avatar
Where can I get it?
Old May 9, 2013 | 09:36 AM
Arielao's Avatar
Bulb chart
Thanks!
cadman
Nov 13, 2025 08:57 AM
Michael_s
Sep 11, 2015 08:03 PM
vchris
Cayenne 955/957
Aug 25, 2015 05:37 AM
metzkaro
Aug 24, 2015 02:59 PM
Jeff1smith
Aug 19, 2015 09:41 PM
