245's up front for the track?
have any of you trakkie's run 245's (and 305 rear) on the track? impressions? handling changes? any info would be great as i am about to order another set of 888's and am thinking about making the change...
I'd get the standard sizes as they're 2 pounds lighter per tire. The Toyo 888 305 in comparison gives you less than 10mm more tread width (not all of which is rubber) but at an unsprung weight/rolling mass disadvantage, which will adversely affect acceleration and braking.
When I was running MPSS tires I first ran 235 fronts then switched to 245 fronts and that helped a little. Then I switched back to 18" 245/305 combo and that was the best improvement with Nitto NT01. I ran Toyo R888 19" 235/305 and then 255/315 18" and 245/305 18"... R888 are not great tires and lately have been having a tread seem splitting issue. Tire Rack took back 4 tires this year and 2 last year due to this issue with R888.
I run 235/295 MPSS for DD. But for the track and DE events I purchased a set of 18" CCW wheels and run 245/305 Nitto NT01. Along with my other suspension mods and alignment settings, the understeer is dialed out and car feels balanced.
Jul 29, 2019 11:13 AM
Enemy
Nov 10, 2015 08:01 AM
PenguiN
Sep 15, 2015 11:44 AM
