Backup lights to led.
Old Sep 1, 2013 | 08:23 AM
slicky rick's Avatar
slicky rick is a glorious beacon of lightslicky rick is a glorious beacon of lightslicky rick is a glorious beacon of lightslicky rick is a glorious beacon of lightslicky rick is a glorious beacon of lightslicky rick is a glorious beacon of light
Anybody done this mod. Our bak up lights are the ordinary halogens. Was wondering if anyone has found an led replacment. The bulbs look very unique but are nevertheless ordinary ones
Old Sep 1, 2013 | 09:36 AM
jhbrennan's Avatar
I thought you had a 997.2? If so, doesn't the entire tail light assembly consist of LED's?
Changing Light-Emitting Diodes and Long-Life Bulbs
The following lights are equipped with light- emitting diodes (LEDs) or long-life bulbs and cannot be replaced individually. Replacement also involves a greater amount of installation work.
– Side light, front,
– Daytime driving lights,
– Tail lights and
– Additional brake lights
f Have the defective light replaced at an authorized Porsche dealer.
Old Sep 1, 2013 | 04:01 PM
Hi jh. Yes its a 997.2 practically all the bulbs at the rear are led's exept the back up lamps. Hmm i guess not a lot of people know this. They are brothers and sisters. Except again they are not your ordinary halogens or t10 or whatever commor bulbs you can buy. They are special lamps in a very unique holder. O should have taken a picture when i dismantled. I tried to remove the bulb from the holder but it would not budge. Wanted to change to high output leds
Old Sep 1, 2013 | 04:44 PM
jhbrennan's Avatar
Couldn't remove the bulb - maybe that's why no replacement bulb is listed. How dark is it where you live where you need high output backup lights...you're spending too much time in reverse.
Old Sep 2, 2013 | 04:44 AM
Hehehe you make me smile. Go into reverse just when i need to back up. It just seems out of place that the whole cluster is led and the back up lamps light up yellowish. You know what i mean.... so if there was an led replacement for that thing i would surely consider it. But, there is a big but, only if it provides equal or more lumens...
Lowtush
Jan 25, 2022 10:48 AM
Airbus Driver
Cayenne 958
Sep 2, 2015 12:50 AM
inamjetdriver
Aug 31, 2015 08:01 PM
GSR Autosport
Aug 26, 2015 05:20 PM
Lifeisgood2
Aug 19, 2015 10:02 AM
