Engine Sound
Old Sep 25, 2013 | 04:09 PM
Romysc4s's Avatar
Romysc4s has much to be proud ofRomysc4s has much to be proud ofRomysc4s has much to be proud ofRomysc4s has much to be proud ofRomysc4s has much to be proud ofRomysc4s has much to be proud ofRomysc4s has much to be proud ofRomysc4s has much to be proud of
If you need a good indy, call Tony Callas @ Callas Rennsport.
310-370-7038
http://www.callasrennsport.com/
Old Sep 25, 2013 | 04:38 PM
MYC2SPC's Avatar
MYC2SPC is just really niceMYC2SPC is just really niceMYC2SPC is just really niceMYC2SPC is just really nice
Please let us know the outcome!Good luck,hope it's a minor issue.
Old Sep 25, 2013 | 09:41 PM
jabed92694's Avatar
jabed92694 is infamous around these parts
Thanks will do! It's going to the dealer tomorrow.
Old Sep 28, 2013 | 01:31 AM
jabed92694's Avatar
Well I got some bad news. Dealer determined the sound is coming from the water pump bearing and I need a new water pump It seems rather early for a water pump as my car is a 07 4S with only 48k miles?!?!
Anyways that was definately the diesel sounding noise I was describing. I just wanted to update everyone.
Jon
Old Sep 28, 2013 | 01:51 AM
cab83_750's Avatar
cab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud of
Jon
I have an 07 4s also (56k miles). If you search long enough, you'll notice that some only last for 35k. Others at 60k.
Based on my research and experience, I would replace mine again at 45k as a preventive item.
Old Sep 28, 2013 | 07:32 AM
Michaelwww's Avatar
Michaelwww is a jewel in the roughMichaelwww is a jewel in the roughMichaelwww is a jewel in the rough
Bad water pump sounds like good news to me.
Old Sep 28, 2013 | 08:19 AM
Robocop305's Avatar
Robocop305 is just really niceRobocop305 is just really niceRobocop305 is just really niceRobocop305 is just really nice
I agree!
Old Sep 28, 2013 | 09:05 AM
mattyf's Avatar
mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !
Thanks for the update. Bad water pump is fairly common. Some even do preventative replacement around 40k.
No big deal really. If you want to put a third radiator kit on, now is a good time.
Old Sep 28, 2013 | 09:27 AM
jabed92694's Avatar
Ok thanks! Anything else I can do preventative you guys recommend now? I read about a low temp thermostat in other posts. Is this worth doing?Anything else?
Old Sep 28, 2013 | 11:29 AM
cab83_750's Avatar
Very well worth it? I would have done it the very first day I owned the car had I known about it.
Watch out for your alternator also. I suspect it would go bad around 50-60K. Mine did.
Last note on the water pump: I am a DIY. Contrary to articles, I had to remove my exhaust to work on the water pump. Just FYI.
Old Sep 28, 2013 | 10:59 PM
jabed92694's Avatar
Does anyone know if the lower temp thermostat is a factory OEM part? Also if they are changing the water pump anyways, is there any extra labor in adding the third center radiator too?
Old Sep 29, 2013 | 01:26 PM
mattyf's Avatar
There's extra labor and parts cost for the 3rd radiator. I believe SunCoast has a kit. It's not necessary, but some folks have added it to help keep things cooler plus added piece off mind. I was just throwing it out there since the Porsche coolant is a little pricey and if it was a mod you were considering, now is a good time.
Old Sep 29, 2013 | 02:27 PM
Robocop305's Avatar
I don't see adding a 3rd radiator is needed unless you track the car.
Old Sep 30, 2013 | 12:43 AM
jabed92694's Avatar
Probably not needed but some say it's a good idea since it keeps the engine temp down even in normal driving. Seems keeping the engine temp low reduces engine risks. I was just wondering if now is a good idea since they are doing the water pump and I could save on some labor cost.
Old Sep 30, 2013 | 08:15 AM
mattyf's Avatar
You won't save on labor really, just the coolant flush since they already have to open the system. I put it out there because it's a popular mod. But if you weren't already considering it, don't sweat it, just do the pump.
