2005 C2S cruise control light not working
Old Oct 10, 2013 | 02:27 PM
floatingkiwi's Avatar
floatingkiwi is infamous around these parts
Cruise control is working but the light doesn't go on anymore - I assume the light in the cluster is stuffed but can the computer get confused? Also seems to take a few tries to engage the cruise control, but the absence of the light may be confusing me.
Light doesn't come on when ignition key is turned on and I'm pretty sure it used to.
Matt
Old Oct 10, 2013 | 03:25 PM
myw's Avatar
myw
myw is a splendid one to beholdmyw is a splendid one to beholdmyw is a splendid one to beholdmyw is a splendid one to beholdmyw is a splendid one to beholdmyw is a splendid one to beholdmyw is a splendid one to behold
100% the cruise light comes on when key is turned in.
my lexus suv fog light-dash light indicator went out... and its been out for a while (foglights work fine).
the annoying thing about these dash light issues is that the mechanism in question normally is fine, but its the dash bulb that has blown... and 99% of the time the entire dash cluster needs replacement. no single replacable/removable bulb.
Matt
Old Oct 13, 2013 | 02:12 PM
I have the manual and can see how to remove the cluster. Would the lamp be replaceable/resolderable? Or completely sealed inside it?
Old Oct 25, 2013 | 03:12 PM
Bump
Old Mar 4, 2017 | 09:30 AM
dmislovi's Avatar
dmislovi is infamous around these parts
I have the same problem did you fixit?
Old Mar 4, 2017 | 11:05 AM
Yes, it was from the flat battery. You need to do a "handover" to reinitialize the car. The durametric wont do this.
Old Apr 27, 2020 | 03:09 PM
autobahnburner's Avatar
autobahnburner is infamous around these parts
Hello all, I'm experiencing the exact problem as the original poster. I've tried doing a vehicle handover through the PCM with no luck. Light does not come on at startup or when the cruise is engaged. Cruise otherwise works flawlessly. Any ideas? Really hoping it's not a bad instrument cluster (all of the other indicators work fine) as those are pricey to replace.
cadman
Nov 13, 2025 08:57 AM
Lowtush
Jan 25, 2022 10:48 AM
2lflat4
Nov 18, 2019 05:05 PM
turbotuner20v
Sep 11, 2015 12:02 PM
