TPMS Replacement -- Thanks
Old Feb 16, 2014 | 01:37 AM
SRV-Drum's Avatar
SRV-Drum is infamous around these parts
My TPMS sensors in my 2007 C4S finally started going. After researching the many helpful posts on the forum I went with a new set from OE Wheels. Had my local Discount Tire swap them out last week. So far everything looks good. Checked them with my Durametric and I have 84 months left on the batteries.
Thank you for all the helpful posts. Love this board!
Old Feb 16, 2014 | 01:47 PM
cerbomark's Avatar
cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !
interesting... I have a durametric tool also and didn t see how you can see the battery life on the sensors?
Old Feb 16, 2014 | 02:41 PM
SRV-Drum's Avatar
Cerbo -
I'm using ver 6.3.2.5 of the Durametric software. In the Tire Pressure folder, go to Actual Values. From there you can select the "Remaining battery life" for each wheel. Hit the F6 button if you want to stop the graphing. There's also a option for remaining battery life with no wheel specified. My guess is that is showing the average life for all 4 sensors.
Hope this helps.
Old Feb 16, 2014 | 02:49 PM
cerbomark's Avatar
Originally Posted by SRV-Drum
Cerbo -
I'm using ver 6.3.2.5 of the Durametric software. In the Tire Pressure folder, go to Actual Values. From there you can select the "Remaining battery life" for each wheel. Hit the F6 button if you want the stop the graphing. There's also a option for remaining battery life with no wheel specified. My guess is that is showing the average life for all 4 sensors.
Hope this helps.
Thanks, I ll try it next time I am plugged in for something.
BlueTurboS
Aug 4, 2020 08:24 PM
Jun 10, 2017 07:45 PM
gulf gt
Aug 27, 2015 10:27 AM
00aston
Aug 24, 2015 09:29 AM
