CTEK Battery Maintainer
Old Jun 10, 2014 | 05:01 PM
Gpjli's Avatar
Gpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud of
The problem with using the connector w tabs broken for me was that when first plugged it it would register charging. When I went back however I would often be met with both lights lit or flickering showing bad connection. It does not charge under those conditions. If you are going to leave it unattended for any time I would recommend you get replacement connector.
Old Jun 10, 2014 | 05:27 PM
GS997S's Avatar
GS997S has a reputation beyond reputeGS997S has a reputation beyond reputeGS997S has a reputation beyond reputeGS997S has a reputation beyond reputeGS997S has a reputation beyond reputeGS997S has a reputation beyond reputeGS997S has a reputation beyond reputeGS997S has a reputation beyond reputeGS997S has a reputation beyond reputeGS997S has a reputation beyond reputeGS997S has a reputation beyond repute
Thanks. Problem for me is I have the Porsche branded CTEC charger and the connector is hardwired to the charger so it can't be replaced. I will take it back to my Porsche dealer and tell them to give me another charger. The tabs seem like a very poor design.
Old Jun 10, 2014 | 07:23 PM
koop's Avatar
koop has a spectacular aura aboutkoop has a spectacular aura about
i have the porsche branded one with broken tabs, seems to work fine
Old Jun 11, 2014 | 05:43 AM
GS997S's Avatar
At least I am not the only one. The tabs seem like a poor design.
Old Jun 13, 2014 | 11:17 AM
Forse's Avatar
Forse is infamous around these parts
I've used the Porsche one with no tabs for two years, and it charges properly (solid green light). However, I only use the cigarette lighter socket, which seems to hold the plug pretty tight.
996_717
Jan 27, 2022 04:04 AM
ant_8u
Apr 10, 2016 11:42 AM
laz74
Oct 2, 2015 06:08 AM
gadgetman
Sep 10, 2015 03:29 PM
