running the engine with MAF disconnected?
Old Apr 14, 2015 | 07:30 PM
TepsonTech's Avatar
TepsonTech is infamous around these parts
Question running the engine with MAF disconnected?
Hello, Sixspeeders
911 is always my dream car and I just finally got an 07' C2 after years of hard work. It's been a wonderful week but after a couple of rainy days she starts making ringing noise. I suspect one of the pulleys might causing it. Do you know if I can run the engine with the air filter box remove ie. MAF sensor disconnected to gain better access to the pulleys?
Old Apr 14, 2015 | 08:04 PM
namronorman's Avatar
namronorman Is a GOD !namronorman Is a GOD !namronorman Is a GOD !namronorman Is a GOD !namronorman Is a GOD !namronorman Is a GOD !namronorman Is a GOD !namronorman Is a GOD !namronorman Is a GOD !namronorman Is a GOD !namronorman Is a GOD !
You can and I even did so today. I find that when I do it, I have to give the car a little bit of gas for the first few seconds of starting it but just a little bit so it won't stall then the ECU will adapt to a baseline and idle just fine.
Old Apr 17, 2015 | 04:24 PM
Gpjli's Avatar
Gpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud of
Congratulations on your new addition. Good luck.
Old Apr 27, 2015 | 10:50 PM
carrera4slakem's Avatar
carrera4slakem is infamous around these parts
never tried but the rain does make the car squeal temporarily if enough gets on it. don't think that is abnormal.
enjoy!
tropicatango
Jun 8, 2025 01:00 PM
Jul 29, 2019 11:13 AM
Money2536
Sep 1, 2015 04:56 AM
ECS Tuning - MB
Aug 21, 2015 02:25 PM
Yotam Refael
Cayenne
Aug 18, 2015 03:03 PM
