997.2 CEL issue with air flow
Old May 5, 2015 | 06:35 PM
pats911runner's Avatar
pats911runner is infamous around these parts
I've been trying multiple things to get rid of my CEL which remains a challenge. I changed the air filters from K&N oil metal filters to regular paper filters. All the literature I've read days the oil-based filters gum up the MAF so took them out. I then cleaned the maf with CRC fluid by spraying liberally. Let dry and reinstalled. The CEL came back on immediately. Here are the codes that I got on my Durametric enthusiast cable:
7910 air mass ahead of throttle valve idle no signal communication
9410 implausible mass air flow ahead of throttle valve. value below lower limit value
I then talked to my shop mechanic and he described needing to reprogramming the ECU and told me to redo exactly what I just did except also unplug the battery for 30 minutes . After doing so and reconnecting the battery cable, I found a PSM initialisation error that cleared itself after I drove the car. For a few minutes. Still one day later thr cel light came back on. I haven't had a chance to check the new codes but I am assuming that the code will be the same as before.
So now I am groping then Web for other ideas to try before I break down and buy a new $500 maf sensor. The cable for the sensor is partially melted Btw - about six inches from the housing. It seems to have touched something hot since it loops down from the housing. I am wondering if the partially melted cable may have something to do with it.
In any case, and ideas on where to check and what could be the issue? Thank you.
Old May 7, 2015 | 06:56 PM
Gpjli's Avatar
Gpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud of
I'd think either mas is toast or the cable is shot. Start w the cheapest possibility?
Old May 8, 2015 | 12:40 AM
carrera4slakem's Avatar
carrera4slakem is infamous around these parts
check out rockauto.com
new MAF $42.79
DELPHI Part # AF10161
Flag indicates this part fits vehicles sold in the US Market. It does not indicate where the part was made -- manufacturers produce parts in multiple factories worldwide. Flag indicates this part fits vehicles sold in the Canadian Market. It does not indicate where the part was made -- manufacturers produce parts in multiple factories worldwide. Flag indicates this part fits vehicles sold in the Mexican Market. It does not indicate where the part was made -- manufacturers produce parts in multiple factories worldwide. MFI; Probe Only
Part ImageNext Image
Choose:
$42.79 $0.00 $42.79
tropicatango
Jun 8, 2025 01:00 PM
Jul 29, 2019 11:13 AM
Jun 10, 2017 07:45 PM
Because_R4CEC4R
Aug 23, 2015 08:53 PM
