Need help replacing my door pocket lid
Old Jun 23, 2015 | 08:09 PM
Domer911's Avatar
Domer911 has a reputation beyond reputeDomer911 has a reputation beyond reputeDomer911 has a reputation beyond reputeDomer911 has a reputation beyond reputeDomer911 has a reputation beyond reputeDomer911 has a reputation beyond reputeDomer911 has a reputation beyond reputeDomer911 has a reputation beyond reputeDomer911 has a reputation beyond reputeDomer911 has a reputation beyond reputeDomer911 has a reputation beyond repute
I have the door panel off, and I’m struggling with the removal of the door pocket lid.
Can anyone shed light on this for me? I haven’t been able to find a DIY.
Thanks for your consideration!
Old Jun 23, 2015 | 09:28 PM
Domer911's Avatar
I figured it out. Will try to post a diy after I tackle the driver side tomorrow.
Old Jun 25, 2015 | 01:40 PM
ryem3's Avatar
ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !
Expect you need to take off the whole armrest, but will look forward to your diy!
Old Jun 27, 2015 | 10:48 AM
bbywu's Avatar
Here is his DIY - thank you for sharing this. I linked it to the DIY section.
Thanks!
Originally Posted by Domer911
STEP ONE: Remove Door Panel (DIY posted in this forum)
STEP TWO: Open the door pocket lid and find a soft surface on which to lay the door (leather down) while you go to work on the inside of the door panel.
STEP THREE: Get a feel for how the pocket lid is hinged, view the retainer pins on each side.
STEP FOUR: Find the U-shaped clip that wraps around the actuating (spring-loaded) hinge. This needs to be removed. Following are pictures that show the clip, and how it's locked into the plastic door panel body. As you pull up on the outer tab with or without a trim tool, applying a little pressure with your finger tip to one of the two outer legs of the perforated section of the clip will release it from the door panel. Be gentle and careful, as you do not want to break the clip.
STEP FIVE: The assembly that holds the orange cog needs to be removed next. It is secured by a few plastic retaining pieces that just need to be squeezed together and pushed through the housing. Pull the cog assembly out as directed in the pic below.
STEP SIX: With needle nosed pliers, carefully remove the spring from the lid as shown in the pic below.
STEP SEVEN: With need nosed pliers, pinch the hinge pieces as indicated in the pic below until the retainer pins are completely disengaged, and push the hinge into the door pocket.
There you go. You can install in reverse order. Good luck!
COBB Tuning
Jan 1, 2025 09:02 AM
Tomp
Mar 27, 2022 05:59 AM
werkzrs
Apr 23, 2020 12:03 PM
pshep138
Sep 1, 2015 09:45 AM
TrackOne
Aug 20, 2015 12:56 PM
