997 engine loom information for a 962 conversion
Old Sep 14, 2015 | 07:07 PM
Gtrclive's Avatar
Gtrclive is infamous around these parts
Does anyone have any info on using just the wiring loom and engine ecu to run engine with out car loom attached.
If possible we are looking for a wiring diagram to show whats required to allow engine to run with minimum wiring.
At present we have nearly all the main car loom and some of the control boxes powered up. Engine will power up but will not operate starter.
Old Sep 15, 2015 | 09:37 AM
semicycler's Avatar
semicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond repute
997.1 wiring diagrams, not sure how long the link will be active: http://1drv.ms/1FKxuFk
Also be sure the PAS system (Porsche Access System) is wired in. There is a micro transponder in the key fob that PAS needs to see before starting the car.
Old Sep 16, 2015 | 02:49 PM
FlaHeel's Avatar
Putting a 962 on the road with 997 stuff or just upgrading electrical?
Old Sep 17, 2015 | 09:45 AM
Gtrclive's Avatar
Fantastic thanks a lot for the drawings....
This is a 962 recreation with the GT3 Heart, but for the road. Not a Turbo motor but 400+ Hp in 950 kgs will still be fun.....
I have a build thread on PH if you want I'll post a link.....
Old Sep 17, 2015 | 01:05 PM
rob001's Avatar
rob001 is infamous around these parts
Following this build on PH for a while with all the 3d modelling and machining parts pictured in great detail. Forget Uri Geller when it comes to change metal shapes! Clive's build and skills is one of a kind
Old Sep 18, 2015 | 12:19 AM
Gtrclive's Avatar
Well it lives ......
http://youtu.be/KEwGNYTcqCU
Murf4
New Member Introductions
Sep 3, 2015 10:10 AM
vr6tee
Aug 29, 2015 03:52 AM
ECS Tuning - MB
Aug 21, 2015 02:25 PM
Aug 21, 2015 06:34 AM
