Upcoming weekend project need advice
I'm afraid I don't understand the lubricant here. The shims (actually vibration dampers in this case) have an adhesive that purposely binds them to the brake pad... lubricant will prevent this. The use of lubricant on our OEM brake pad installations is not a Porsche recommendation that I am aware of. Mine work just fine and have no noise with just the sticky shims and no lubricant.
BTW, the sticky shims can be popped off the pads with a long putty knife or other thin blade so they are not really permanently glued to the pads. To get the pads out without removing the calipers I've had to slide a blade in to pop the shims free of the pad since the shims will hold the pads locked into the pistons (unless you remove the whole caliper).
I think it works more as an insulator than a lube. One of my previous posts suggested it is not needed but wouldn t hurt if he felt inclined.
Anyway don't the shims lock into place? Then adhesive isn't essential?
I think the key here is using a small amount to absorb vibration. There are a few indies that apply grease to the back of pads and also around the lip of the piston where it makes contacts with the shim/dampener.
I've certainly seen some do away with the shims since they aren't cheap and are a little annoying to remove. Then you just let the pistons contact the metal backing of the pads. If you do this, then the brake anti-squeal lube between the piston and the pad backing becomes desirable to prevent squeal... just like on most cars.
I'd recommend one or the other, but not lube AND shims. I decided just to cough up the extra bucks and stick with the OEM approach since it seems to work well. I was also able to salvage more than half of the original shims since they were still sticky after I popped them off and returned the remaining replacement ones to save a few dollars.
Dang, sorry to hear that. I've changed the pads on two different 997s without lube and never had a squeal. Did you follow a bedding procedure? If not, that could explain it. Here is the bedding procedure that I've used for my Hawk ceramic pads:
Bed-in / Burnishing Instructions
1) After installing new brake pads, make 6-to-10 stops from approximately 30-35 MPH applying moderate pressure.
2) Make an additional 2-to-3 hard stops from approximately 40-45 MPH.
3) DO NOT DRAG BRAKES!
4) Allow at least 15 minutes for the brake system to cool down.
After step 4 is completed, your new Hawk Performance brake pads are ready for use.2) Make an additional 2-to-3 hard stops from approximately 40-45 MPH.
Franc01
Oct 13, 2015 01:13 PM
PelicanParts.com
Oct 7, 2015 02:30 PM
PelicanParts.com
Oct 7, 2015 02:26 PM
