Audio input optoins
Old May 11, 2016 | 11:00 AM
tbills's Avatar
tbills is infamous around these parts
Audio input optoins
Are the only options to play music from my mobile phone (iPhone) through the Aux chord? The USB charges my phone but I can't get it to play. Is that not an option?
Old May 11, 2016 | 11:25 AM
Dennis C's Avatar
What year is your car? Which radio do you have? It sounds like you have a 997.2 with PCM 3.0. I believe the the answer to your question is: "yes".
I have an aftermarket kit from Mobrigde that allows me to stream bluetooth audio. It works well.
Old May 11, 2016 | 11:35 AM
tbills's Avatar
2010 4s
Old May 11, 2016 | 01:02 PM
Dennis C's Avatar
I think you'll need to add an aftermarket solution to stream bluetooth audio. I like Mobridge, but there is a cheaper, FM modulated solution called Tranzit Blue that lots of people seem to like.
Old May 11, 2016 | 06:14 PM
sleepy's Avatar
sleepy is infamous around these parts
You need a separate Y-cable that plugs into both the USB and iPod port inside the center armrest. It's about $35 from your Porsche dealer.
Since PCM 3.0 was designed in 2008, that iPod cable uses the old 30-pin iPod connector. If you have a recent iPhone with the Lightning port, you need a 30-pin to Lightning adapter from Apple as well.
Old May 12, 2016 | 08:14 PM
Edman951's Avatar
Edman951 is infamous around these parts
This is the cable you are looking for , and as stated by sleepy, you will need an adaptor if you have lightning plug.
http://www.suncoastparts.com/product/I612C47102.html
rhart6
May 10, 2016 09:02 AM
SJFZ1
May 10, 2016 09:00 AM
