How do i engage horn sound upon lock?
Old Sep 11, 2016 | 10:04 PM
Harry Da Hamster's Avatar
Harry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud of
I found a solution. My glove compartment can partially close (and stay closed) without engaging the sensor. This will give me a loose compartment handle, but it doesn't rattle. And it solves my issue with getting the horn to sound.
Old Sep 12, 2016 | 04:47 AM
jhbrennan's Avatar
Originally Posted by FNG
Obviously, you haven't read anything else in the thread other than the OP. No need to explain again.
Besides, the horn sound upon lock is very soft in volume and only uses the higher pitched horn which is more pleasant to the ear and not obnoxious at all.
The alarm actually has its own horn...near the brake master cylinder. Open the hood, arm the car and you'll hear the location when it honks to indicate the hood is open. I wouldn't characterize the sound as "soft" but we all have different levels of acceptable sound pollution.
Old Sep 12, 2016 | 02:37 PM
Did not know that! OK, "softer" than most alarm chirps
Old Sep 12, 2016 | 02:54 PM
floatingkiwi's Avatar
floatingkiwi is infamous around these parts
No, not on all cars or markets.
Old Sep 15, 2016 | 10:45 PM
mattyf's Avatar
mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !
Originally Posted by cairo94507
Why in the world would anyone want their car to honk when you lock it? To draw attention to your car? That is way to low-brow and just irritates everyone around when you lock the car.
Agreed. So tacky.
Plus looking back at your beautiful car blinking "good-bye" at you is the best.
Old Sep 16, 2016 | 03:10 PM
Originally Posted by mattyf
Agreed. So tacky.
What's more tacky? The common (for most other cars) audible indication your car is locked? Or people watching you stare at your car?
Old Sep 16, 2016 | 03:48 PM
mattyf's Avatar
I bet you leave your spoiler up too.
Old Sep 16, 2016 | 08:54 PM
You know what's most tacky? Your assumptions.
Old Sep 17, 2016 | 09:25 PM
Kellen's Avatar
Kellen has much to be proud ofKellen has much to be proud ofKellen has much to be proud ofKellen has much to be proud ofKellen has much to be proud ofKellen has much to be proud ofKellen has much to be proud ofKellen has much to be proud of
I bought the remotekey (mods4cars) for this reason. I would lock it but couldn't hear the locks work and would constantly double check. I put it on the chirp only with lock, its not loud or obtrusive to me. Plus the one touch up for passenger window is nice but it is only from the drivers side. Biggest thing I like now is auto windows up/down from the remote. Real nice to help air out the car or use it to put something in the passenger side before getting in.
You can have it use the horn or the alarm. Horn is much quieter than the alarm.
Old Sep 17, 2016 | 10:40 PM
Petza914's Avatar
Petza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond repute
With a Durametric, you can code everything you just described except the horn chirp, without needing to purchase that module - I've done it in both my 997s.
Enabling the "comfort windows" feature makes a long hold of the key remote when unlocking the car power the windows down and a long hold when locking the car power the windows up. Passenger window goes up all the way if you just hold the up button on the driver's door for about half a second then let go.
Old Sep 17, 2016 | 11:14 PM
^Sweet. I got a Durametric Enthusiast in transit now. I've solved my issue with the audible lock indicator using the glove box trick
Old Sep 17, 2016 | 11:17 PM
Petza914's Avatar
Unfortunately, you need the Pro version to do options Coding.
Old Sep 18, 2016 | 03:22 PM
LOL! Turning off the maintenance light alone was worth it anyway. What does the Enthusiasts version do besides that?
Old Sep 18, 2016 | 05:51 PM
semicycler's Avatar
semicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond repute
Enthusiast can read and clear codes, and read the DME overrevs. It can also reset the airbag light which other readers cannot do. Enthusiast is tied to a VIN, 3 VIN's max. Used ones come up for sale from time to time in the marketplace.
The Pro version does everything the enthusiast version can do, is more expensive, has unlimited VIN's, and enables coding features. I've used it to control the comfort windows and to disable the rear spoiler when I swapped to a fixed wing.
Old Sep 20, 2016 | 01:38 PM
stevepow's Avatar
stevepow is a glorious beacon of lightstevepow is a glorious beacon of lightstevepow is a glorious beacon of lightstevepow is a glorious beacon of lightstevepow is a glorious beacon of light
Originally Posted by Dennis C
I have this product in my cabriolet. It is very nice. I don't use the horn beep when locking function, but I like many of the other functions.
Have had this in my car almost as long I have had the car. Works great. I like the horn confirmation - some don't - no big deal.
