997.2 rear LED light enclosure: Water Entry
Old Sep 21, 2017 | 11:51 AM
LPpfs997's Avatar
LPpfs997 is a splendid one to beholdLPpfs997 is a splendid one to beholdLPpfs997 is a splendid one to beholdLPpfs997 is a splendid one to beholdLPpfs997 is a splendid one to beholdLPpfs997 is a splendid one to beholdLPpfs997 is a splendid one to beholdLPpfs997 is a splendid one to behold
I have seen the 'moisture' within the left taillight light assembly for a few years now. The left taillight stopped functioning recently; illuminated but the turn signal & flasher ceased. I removed the light assembly this morning; +30 oz. of water drained out. After carefully removing the backplate I could further dry the interior portion and the flasher began to function though not consistently.
Further drying with a hairdryer has resolved that problem. The seal where the clear lens meets the red portion appears to be the source of water entry. I have posted the interior view since I hadn't seen an image showing all of the stuff working in there. I still can't get approx. 40% of the outer LED's to illuminate. Any suggestions ?
Have any other 997.2 owners found this issue ? Mine is a 2009 c4s :-) 35k on the clock.
Paul
997.2.LED LeftTail after water removed
997.2.LED LeftTail interior
Old Sep 22, 2017 | 06:00 AM
Petza914's Avatar
Petza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond repute
I think you're going to need to buy a new left 997.2 taillight. Like water entry into a smartphone, once some of those electrics get wet, you can't bring them back. You might try sealing it in a plastic bag with some dessicant packets that will absorb any remaining moisture out of the components. If you don't have access to dessicant packets, rice (the kind you eat) will do a similar thing, jut not as quickly
Old Sep 22, 2017 | 11:32 AM
jhbrennan's Avatar
https://rennlist.com/forums/997-forum/1025451-moisture-in-the-tail-light-issues.html
Old Sep 24, 2017 | 09:29 AM
LPpfs997's Avatar
Thanks jhbrennan, I have ordered a replacement; found a crack; ULO coming Monday.
Old Sep 25, 2017 | 02:26 PM
LPpfs997's Avatar
to 6speedonline Users : PartsGeek provided a OEM replacement for the 997.2 left rear tail unit; $418 w/ shipping; two days. Fully operational.
Paul
Old May 30, 2022 | 05:49 AM
HeloiseBurgess's Avatar
HeloiseBurgess is infamous around these parts
Apparently, because of the moisture, now you've damaged your headlights, and you need to buy a new LED light for your car. Considering the price of LED lights today, I don't think you will spend a lot of money on them, and I advise you to buy LED headlights from VONT. I learned about them from Amazon and bought LED Light only from this company because their products are cheap but very high quality. I recently ordered a smart bulb from Amazon for my room. As far as I understand, if you use an LED smart bulb, you can configure any light you need using the software.
mblueracer
Apr 17, 2023 09:18 AM
Stroker
Feb 11, 2014 02:25 PM
esilvin
11
Sep 23, 2013 06:43 AM
Mark Harris
Jun 2, 2012 12:02 AM
