Transmissions Problem
Old Apr 11, 2018 | 11:39 PM
Bong Yung Heng's Avatar
Bong Yung Heng is infamous around these parts
Unhappy Transmissions Problem
Transmission not changing gear , any solution ? It will revs only in drive " D " only way to shift gear is through M mode
Old Apr 12, 2018 | 05:32 AM
Petza914's Avatar
Petza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond repute
When in D, does the dash show that it's in automatic mode and not manual mode. Maybe the switch in the shifter gate that knows which position the shifter is in has gone bad. You can probably also force a reset of the control module by disconnecting the battery for 10 minutes and see if that does anything.
Old Apr 12, 2018 | 10:08 PM
Hello , it was in D .. Already force reset a lot of times .. it was still the same
PitbullSL500
May 20, 2009 12:46 PM
eclou
Feb 5, 2009 11:15 PM
spinntt
Jul 2, 2005 11:06 AM
