Fault Code Help
Old Jun 1, 2023 | 10:41 AM
GCB's Avatar
GCB
GCB is infamous around these parts
Fault Code Help
Anybody familiear with these 2 codes that frequently are popping up? My Duremetric displayed these codes.
I have cleared them before, but they return intermittently.... usually only throws the code during idleing for prolonged time (~3-5 min) and when engine is warmed up.
Absolutely no misfires or problems noticed with driving. O2 sensors are only about 1-1/2 years old. OEM Cats do have about 175K miles on them.
Fault codes seem contradictory to each other? one says too rich.. while other says... too lean. Before I think about even replacing Cats... I need to know if thats the issue?
any suggestions? Thanks all!
P 2198 O2 Sensor Signal Biased / Stuck Rich Bank 2 sensor 1
P 2272 Oxygen Sensor Signal behind Cat. Converter, Bank 2 too lean
Old Jun 17, 2023 | 12:30 AM
Jlove's Avatar
Jlove is infamous around these parts
This is interesting that they contradict. I would start by watching ltft and stft fuel trims on bank 2 to see if it really is running rich ( I suspect this is your real problem) the after cat fault is just likely an effect of front O2 sensor reading so rich.
Sling Shot
Mar 20, 2023 08:44 PM
motonicholas
Mar 8, 2022 01:32 AM
shahriar35
Sep 15, 2021 12:13 PM
Yves
Apr 11, 2020 04:06 PM
jetengine
Cayenne 955/957
Oct 15, 2019 04:19 PM
