Brembo Brake Kits From Exotica Motorsports!
Old Jun 21, 2007 | 12:30 PM
ExoticaPorsche's Avatar
ExoticaPorsche is infamous around these parts
993 Front1995-1998 355x32 2-Piece$3,295.00
993 Front1995-1998 355x32 2-Piece$3,495.00
993 Front1995-1998 380x32 2-Piece$3,595.00
996 C2 Front1999-2004 355x32 2-Piece$3,295.00
996 C2 Front1999-2004 355x32 2-Piece$3,495.00
996 C2 Front1999-2004 380x32 2-Piece$3,595.00
996 C2 Front1999-2004 380x32 2-Piece$3,995.00
996 C2 Rear1999-2004 345x28 2-Piece$2,995.00
996 C2 Rear1999-2004 380x28 2-Piece $3,195.00
996 C4 Front1999-2004 355x32 2-Piece$3,295.00
996 C4 Front1999-2004 355x32 2-Piece$3,495.00
996 C4 Front1999-2004 380x32 2-Piece$3,595.00
996 C4 Front1999-2004 380x32 2-Piece $3,995.00
996 C4 Rear 345x28 2-Piece$2,995.00
996 C4 Rear 380x28 2-Piece $3,195.00
996 C4S, Turbo Front 355x32 2-Piece$3,495.00
996 C4S, Turbo Front 380x32 2-Piece$3,595.00
996 C4S, Turbo Front 380x32 2-Piece$3,995.00
996 C4S, Turbo Rear 345x28 2-Piece$2,995.00
996 C4S, Turbo Rear 380x28 2-Piece $3,195.00
997 C2 Front2005> 355x32 2-Piece$3,295.00
997 C2 Front2005> 355x32 2-Piece$3,495.00
997 C2 Front2005> 380x32 2-Piece$3,595.00
997 C2 Front2005> 380x32 2-Piece$3,995.00
997 C2 Rear2005> 345x28 2-Piece$2,995.00
997 C2 Rear2005> 380x28 2-Piece $3,195.00
997 C2S Front2005> 355x32 2-Piece$3,495.00
997 C2S Front2005> 380x32 2-Piece$3,595.00
997 C2S Front2005> 380x32 2-Piece$3,995.00
997 C2S Rear2005> 345x28 2-Piece$2,995.00
997 C2S Rear2005> 380x28 2-Piece $3,195.00
997 C4 Front2006> 355x32 2-Piece$3,295.00
997 C4 Front2006> 355x32 2-Piece$3,495.00
997 C4 Front2006> 380x32 2-Piece$3,595.00
997 C4 Front2006> 380x32 2-Piece$3,995.00
997 C4 Rear2006> 345x28 2-Piece$2,995.00
997 C4 Rear2006> 380x28 2-Piece $3,195.00
997 C4S Front2006> 355x32 2-Piece$3,495.00
997 C4S Front2006> 380x32 2-Piece$3,595.00
997 C4S Front2006> 380x32 2-Piece $3,995.00
997 C4S Rear2006> 345x28 2-Piece$2,995.00
997 C4S Rear2006> 380x28 2-Piece $3,195.00
997 GT3 Front (Excluding PCCB)2006> 380x32 2-Piece$3,995.00
997 GT3 Rear (Excluding PCCB)2006> 380x28 2-Piece $3,195.00
997 Turbo Front (Excluding PCCB)2006> 380x32 2-Piece$3,995.00
997 Turbo Rear (Exlcluding PCCB)2006> 380x28 2-Piece $3,195.00
Cayenne Front2003> 380x34 2-Piece$4,295.00
Cayenne Front2003> 405x34 2-Piece$4,295.00
Cayenne Rear2003> 380x28 2-Piece $3,195.00
Cayenne Rear (1-Piece)2003> 358x28 1-Piece$2,395.00
Porsche Monobloc Kits (Black Calipers Standard)
911 S, SC, Carrera Front1974-1989 282x24 1-Piece $1,595.00
911 S, SC, Carrera Front1974-1989 322x32 2-Piece$1,995.00
911 S, SC, Carrera Rear1974-1989 322x28 1-Piece $1,895.00
911 / 930 Turbo Front1975-1979 322x32 2-Piece$1,995.00
911 / 930 Turbo Front1980-1989 322x32 2-Piece $1,995.00
911 / 930 Turbo Rear1978-1989 322x28 1-Piece $1,895.00
Porsche Lightweight Kits
911S Front1966-1973 313x28 2-Piece$2,595.00
911S Rear1966-1973 305x28 1-Piece $1,895.00
911S Rear1966-1973 313x28 2-Piece$2,595.00
911 S, SC, Carrera Front 313x28 2-Piece$2,595.00
911 S, SC, Carrera Rear 305x28 1-Piece $1,895.00
911 S, SC, Carrera Rear 313x28 2-Piece$2,595.00
Porsche Big Red Kits
911 C2 / C4 Front 322x32 2-Piece $2,195.00
911 C2 / C4 Rear 300x24 1-Piece $1,995.00
993 C2 / C4 Front 322x32 2-Piece $1,995.00
993 C2 / C4 Rear 322x32 2-Piece $1,795.00
944 S/2 Non-M030 (w/o Sport Suspension) 322x32 2-Piece $2,195.00
944 Turbo 322x32 2-Piece $2,195.00
968 Non-M030 (w/o Sport Suspension) 2-Piece $2,195.00
944 Turbo 322x32 2-Piece $1,995.00
944 S/2 M030 (w/ Sport Suspension) 322x32 2-Piece $1,995.00
968 M030 (w/ Sport Suspension) 322x32 2-Piece $1,995.00
  1. Requires minor modification to the OEM steering knuckle
  2. Requires minor modification to the OEM steering knuckle and use of included custom hubs
  3. 1995 E36 M3 models require minor modification to the lower control arm outboard of the ball joint
  4. This system consists only of 2-piece disc assemblies which directly replace the OEM discs
  5. Requires significant modification to the OEM knuckle
  6. This system eliminates the parking brake function if not used in conjunction with parking brake kit
  7. This system eliminates the parking brake function
  8. This system is to be used ONLY with OEM rear brakes, not to be used with the rear upgrade kit
  9. Special order only
*Blue = Subject to longer lead times. Green = New applications. Call for availability.
Old Jun 21, 2007 | 04:41 PM
lardog's Avatar
lardog is a name known to alllardog is a name known to alllardog is a name known to alllardog is a name known to alllardog is a name known to alllardog is a name known to all
what is it difference? how many pistons? what color Calipers?
Old Jun 22, 2007 | 12:01 PM
I had this post set up and looked great. I hit the post button and it jumbled it all. So I quickly edited it to make it readable so some of the info was lost. To answer your question the first kit is a 4-piston kit with Black, Red or Silver calipers for $3595. The second is a 6-piston kit with Black, Red, Silver or Yellow calipers. We also are lucky in that we can offer custom caliper colors. For $300 more we can have your calipers painted with any color code you give us. Let me know if you would like to get a set going. Thanks.
ECS Tuning - VW
Aug 20, 2015 03:07 PM
PelicanParts.com
930 Turbo Vendor Classifieds
Aug 18, 2015 04:01 PM
PelicanParts.com
964
Aug 18, 2015 03:57 PM
PelicanParts.com
964 Turbo
Aug 18, 2015 03:56 PM
PelicanParts.com
993 Vendor Classifieds
Aug 18, 2015 03:55 PM
