Bad parking
Old Jul 3, 2008 | 02:31 PM
mannytt's Avatar
mannytt is infamous around these partsmannytt is infamous around these parts
suck's to be the owner of that vette, look's like he put some work into the engine.
Old Jul 3, 2008 | 02:33 PM
BLOWNGTO's Avatar
BLOWNGTO is infamous around these parts
Originally Posted by SSNISTR
Nobodies I know with stock internals etc has gotten anywhere near mid 500's with a blower. Figure a stock LS1 Vette, around 300-325, add 100-150 at most for the blower and your in the mid 400's. To put on a big blower on you need to lower compression and do other mods. Then you will get over 500 easy....
My car did 520 with the blower at 7 psi I added headers and it did 530 so mid 500 is possible with a stock ls block.
Old Jul 3, 2008 | 05:28 PM
ZFSix's Avatar
ZFSix is infamous around these parts
Yep. I've seen heads/cam/FI ls1's pull 600rwhp on stock bottom end. Heck, LS2s pull over 700rwhp on stock bottom end with heads/cam/FI.
Pretty much any reputable shop has done numerous cars with that kind of power on stock motors.
Looking at the pics though, he has aftermarket fuel rails and fuel lines which usually means big power.
Plus those 2 lines that feed into the intake tube.. maybe meth?
Old Jul 3, 2008 | 06:17 PM
SINISTR's Avatar
SINISTR has a spectacular aura aboutSINISTR has a spectacular aura aboutSINISTR has a spectacular aura about
Never said it couldn't be done with a stock block. I said stock everything, unless you wanna run so much boost you only want 10K out of the engine....
Old Jul 3, 2008 | 06:19 PM
itsfast's Avatar
itsfast is infamous around these parts
Still looks staged, but no matter....that car is messed up! I hope the roll bar made a difference. I see a wide body conversion on the rear and a big brake kit....nice.
The numbers I've always heard and seen were low 500whp with that combo. Some C5Z06's are de-tuned to the low 500whp range (530whp or so) since the bottom end tends to not like 550whp+ for very long.
SINISTR's Avatar
Of course! Again, I said STOCK and a blower your not gonna put down 550....
My old car with just heads and cam did 450+.
MJM911
New England
Oct 15, 2015 07:39 PM
xbox_fan
Sep 13, 2015 01:25 AM
MC36
Southeast
Sep 1, 2015 06:39 PM
