Dodge Viper - How are they for maint. ?
Which gen? I don't know about 20k, never heard that. The main expensive piece was the Gen II's clamshell hood which was like 10-15k from the factory but plenty of places offered replacement at lower cost, lot's of people replaced their hoods from insurance and pocketed a nice amount of change too lol. Which is why they went to a much cheaper and cost effective replacement hood on the 3's/4's.
I've been pondering the idea of trading in the STi for a Viper now that I have a dedicated DD and winter car. I currently have my eye on this one: http://www.autotrader.ca/a/Dodge/Vip...0730113443624/
Only the GEN II's appeal to me. I'll be autocrossing whatever I end up getting, how are the gen 2's in terms of handling and braking?
1) I would definitely read Maurice Lang's Viper Buyers Guide before buying any Viper.
2) The clam shell front ends of the Gen1/2 are expensive. Freakishly so and will only be increasing in value and people need replacements. (I seen them as low as $8,000, with some small repair and prep needed....)
3) Gen 2's are great in handling and braking, but they only got ABS in 2001. You'll want that if you're going to track your car (or autocross). No ABS + freakishly expensive front end = heart break.
Gents,
Would like to follow up on this thread as I'm considering one of these.
Torn between third and fourth gen mainly due to difference in price so would love insight on whether the 15-20k USD (at least) gap is worthwhile to top up to a 2008+.
To preface, I wouldn't modify heavily and would keep her naturally aspirated (and off the gas). I'd "daily drive" her in sunny California; and also do a few cross-country excursions (potentially).
- Annual maintenance?
- Known issues across the years?
- Warranty - how well does Dodge stand behind them?
- Drivability in traffic, wet conditions?
Thanks!
Thanks!
cyntaxx,
you'll want to look into the Viper specific forums (VCA for example) for A LOT of discussion on this topic. Based on what you said, you'll want the Gen 4 for sure. I bought a Gen 4 myself after weighing all of the options.
- Annual maintenance? Gas, insurance, oil changes, etc. not so cheap, cheap, cheap.
- Known issues across the years? I had the rear diff replaced in my '08 under warranty.
- Warranty - how well does Dodge stand behind them? Very well.
- Drivability in traffic, wet conditions? Gen 4 is fine. Gen 3 ehhh.....I wouldnt want to do it on a regular basis.
Only part that I know of with a high fail % is the power steering bracket. After you swap this out with ones of the billet ones available you'll only have to open the hood when you change your oil.
The Gen 2 cars now are all @ least 10 years old. All the rubber bushings/mounts should be checked on a reg. basis as well.
The car is very easy to work on so anything you do end up having to swap/replace is pretty easy.
I had a Gen IV ACR and the car was awesome! The car seemed bullet-proof and was a blast to drive even though I was a bit cramped since I'm tall. Insurance on the Viper was less than what I was paying for a ZR1. I miss the quick ratio steering the Viper has... a lot of fun in the corners.
had an 04 and now an 06...04 never had any problems at all. The 06 I've had less than a year has really only had the injector harness replaced...about 2000 bucks...no idea why it happened but I've never heard of any one else having that problem. Easy car to work on too.
im going to be doing a clutch job in a few days on an 08, and im only charging the guy 800. from what i have done so far. its probably one of the easiest cars ive worked on. id say the r35 is more of a pain in the a$$.
owned several Vipers and will purchase the Gen V next summer so that should answer your question right there! Drove my Gen IV ('09 coupe) down to ATCO dragstip in south jersey (2 hr ride in traffic 90 deg temp), ran about 25-30 1/4 mile runs, drove back witn AC blasting. Car will handle anything you throw at it. If you plan on staying stock Gen IV, going to mod '06 Gen III coupe.
I have an 08 acr and it's been bullet proof for me. It did drop an oil pump for the first owner which resulted in a grenaded engine. Dodge was great about it and put a new arrow balanced and blueprinted engine in it. It now makes about 640hp compared to the stock hp. You can get an extended warranty from chrylser for any viper that is very good and almost stupid cheap insurance. For my car with 13k miles it's about 1800 dollars and covers everything for 5 more years.
The other awesome thing about the ACR compared to comparable track worthy cars (Zr1, GT2 RS, etc) is the comsumables are very cheap. My 2 piece 14 inch rotors are $260.
I love the car. It's always an experience driving it. I actually daily drive it and do most of the basic maint myself...it's very easy if you can get it off the ground. It is very low.
