Brembo 2pc Big Brake Rear Rotors for DB9 and Vantage
Brembo Big Brake Kits utilize a much larger rotor with either slotted, drilled or a combination of both to increase stopping performance. With this larger rotor design it allows for a much larger caliper that is capable of more consistent brake pad pressure on the rotors.
This kit from Brembo includes a 2 piece brake rotor designed to further improve the performance of any car while braking. Brembo has spent years developing the Big Brake Kits by combining the needs of an every day driver and track enthusiast with the advanced technology tested and gained from the professional racing divisions. The two piece rotor design included in this kit is a direct result of racing technology. Unlike any 1 piece brake rotors, the 2 piece floating disc allows the rotor to remain in line with caliper, even under extreme conditions such as hard cornering.
Kit Includes:
Available Applications:
-Aston Martin DB9 2003-2011
-Aston Martin V8 Vantage 2006-2011
**Picture for representation only
PM or CALL 480 966 3040 ext 228 for your 6speed member pricing!
Kit Includes:
- 2 piece disc design
- (328mm) 12.9 inch Drilled or Slotted Rotors
- Electronic balancing system
- Perfectly uniform thickness of the braking surface.
- Extremely precise tolerance.
- All necessary hardware for installation.
- This system consists of 2-piece disc assemblies which directly replace the OEM discs
ECS Tuning - VW
Aug 20, 2015 03:07 PM
PelicanParts.com
930 Turbo Vendor Classifieds
Aug 18, 2015 04:01 PM
