My Emissions Service light just came on??
Old Jan 21, 2010 | 09:38 AM
ccrispy's Avatar
ccrispy is infamous around these parts
Everybody lost me I have an aftermarket exhaust on my car.. what is CAT and OEM mean?
Old Jan 21, 2010 | 09:40 AM
cshsia's Avatar
cshsia is infamous around these parts
Cat= catalytic converter.
OEM = Original Equipment Manufacture, aka stuff made by AM.
Old Jan 21, 2010 | 10:27 AM
Stuart Dickinson's Avatar
Stuart Dickinson Is a GOD !Stuart Dickinson Is a GOD !Stuart Dickinson Is a GOD !Stuart Dickinson Is a GOD !Stuart Dickinson Is a GOD !Stuart Dickinson Is a GOD !Stuart Dickinson Is a GOD !Stuart Dickinson Is a GOD !Stuart Dickinson Is a GOD !Stuart Dickinson Is a GOD !Stuart Dickinson Is a GOD !
Hey, help is no problem. All business aside we're all car guys (and gals) so always glad to discuss!
We've never dynoed a set of cats on a Vantage by themselves so I don't have absolute discrete data, but rmdrmd1956 can confirm that aftermarket cats are worth an extra 20rwhp(25bhp) on his supercharged car, and that ours don't throw CEL. Unless I'm mistaken, he had some on from another manufacturer which did. If you apply the same percentage gains to a normally aspirated unmodified 4.3, you should get 20BHP from a set of cats.
You will also notice a couple of other things. The volume of the exhaust note will increase, and will also sound different - a little more raw and aggressive. Weight gains are fairly insignificant, maybe 4 or 5 kilos I'd guess. I also feel (and we have similar feedback from customers) that the throttle response is improved as well.
As far as the O2 stuff - It's just an educated guess but I suspect for a couple of reasons that our cats would be easier on the O2 sensors as the produce less heat in that immediate area.
Originally Posted by cshsia
Hi Stuart,
Thanks for the info. I know it's more of a scientific assessment, but if you observe that the RSC cats run cooler, then I'm willing to give it a shot. The thought of taking the car in 4 or 5 times to get O2 sensors fixed really bothers me. :P
While I do know quite a bit about cars in their stock form, I know very little about aftermarket parts and performance improvements. What difference will I feel or hear with the RSC cats?
btw, thanks for all the help, starting from late last year when i was looking into the idea of purchasing a Vantage.
Old Jan 24, 2010 | 08:57 PM
cshsia's Avatar
When I did the last oxygen sensor fix at the dealership, I was told the other one is on its way out as well. Sure enough today while doing a bit of hard acceleration (7k RPM), pop came the warning light again.
I don't know what to think of this, but it's certainly frustrating. At least I have one year before my car inspection makes this an absolute necessity to fix. However I'll probably try to get it fixed with my cousin, save a bit of money and headache of dropping the car off.
I recall people were buying the part pretty cheap online, time for me to search the forums.
Old Jan 24, 2010 | 09:34 PM
Holson's Avatar
Holson is infamous around these parts
I'm amazed that they didn't just replace the other one while they were at it. Then again I think the labor wasn't so bad when they changed mine..
so it's probably not that bad of a job
sorry to hear but good luck! I think any shop can do this for you - just have to buy the O2 sensor from somewhere.
Old Jan 25, 2010 | 08:08 AM
cshsia's Avatar
$200 for the part, $200+ for labor. Not "too" bad, but then again a lot for the amount of work. I certainly was not happy with the mark-up for the part.
Also wasn't thrilled that they put the car back together before telling me the other one's failing.
Anyways, going to fix the other one locally.
Old Jan 25, 2010 | 02:48 PM
RPVantage's Avatar
RPVantage is a splendid one to beholdRPVantage is a splendid one to beholdRPVantage is a splendid one to beholdRPVantage is a splendid one to beholdRPVantage is a splendid one to beholdRPVantage is a splendid one to beholdRPVantage is a splendid one to behold
http://www.car-stuff.com/store/?N=91...&md=V8+Vantage
I think $28 is the right price.
Actualy the one that cost $32 sounds better.
they also have lots of reviews.
Old Jan 25, 2010 | 02:58 PM
RPVantage's Avatar
Just need to know how many wires does the O2 sensors have???
(the oem)
Old Jan 26, 2010 | 08:54 AM
cshsia's Avatar
I'm curious about that part too, does anyone have experience with that? How many wires is the OE Aston Martin O2 sensor?
I'm buying a OBD reader to check which sensor is faulty, then I'm going to buy my own parts and have it installed locally.
Old May 25, 2010 | 07:31 PM
markesq's Avatar
markesq has a spectacular aura aboutmarkesq has a spectacular aura about
So did anybody change their o2 sensor themselves?
Old Dec 6, 2013 | 05:01 PM
XWCGT's Avatar
XWCGT has a spectacular aura aboutXWCGT has a spectacular aura aboutXWCGT has a spectacular aura about
These cheapo 02 sensors are generic and require you to cut the existing wires and splice in with wire connectors to make it work. normal 02 sensors cost around $200. most of the work is feeding the factory oem part wired into the chassis to connect to the computer, probably near the fuse panel like other cars. still researching.
Old Apr 23, 2014 | 05:13 PM
RicoDB9's Avatar
RicoDB9 is infamous around these parts
I have an 07 DB9 Sport with 27k on it. I have the typical AM battery issues. In fact it just happened to me last week. Battery went dead and "Emission Service" light went on. It has done it before.
IGNORE IT. Make sure your gas cap seal is clean and cap is tight. Drive it for a few hundred miles and it will go out on its own.
WORSE CASE is go into AM and have them reset the code. If it immediately comes back on you may have an issue but I'll bet you 3 beers it doesn't.
With respect to battery tenders, you can buy a fully electronic 2A smart charger for $40 at Canadian Tire... if your patient they go on sale every once in a while for $25. It has a cigarette lighter adapter and I plug it right into the cigarette lighter interface thing in the trunk... works like a jet!!!
http://www.canadiantire.ca/en/pdp/mo...l#.U1hBFF6_fVk
Old Apr 23, 2014 | 05:20 PM
oo7's Avatar
oo7
oo7 is just really niceoo7 is just really niceoo7 is just really niceoo7 is just really nice
I have high flow cats and the emission light comes on in cold weather when engaging in non-spirited driving, i.e. driving like an octogenerian. It will go out on its own but I usually reset with obd. I have been told the high performance cats don't heat up quickly or enough to meet the efficiency threshold.
COBB Tuning
Jan 1, 2025 09:02 AM
Jun 10, 2017 07:45 PM
DetomasoGTS74
Nov 11, 2015 09:01 AM
GSR Autosport
Aug 26, 2015 05:20 PM
Jeff Young
Aug 23, 2015 09:03 PM
