Vantage Battery Conditioner
Old Feb 17, 2010 | 07:31 PM
SonicKrack's Avatar
SonicKrack is a glorious beacon of lightSonicKrack is a glorious beacon of lightSonicKrack is a glorious beacon of lightSonicKrack is a glorious beacon of lightSonicKrack is a glorious beacon of lightSonicKrack is a glorious beacon of light
Hey guys,
How the heck do I connect the battery tender? The battery is dead, cannot open the glove compartment to look at the manual... I really need some help with this issue. Much appreciated.
Old Feb 17, 2010 | 08:03 PM
AstonAficionado's Avatar
Awaiting Email Confirmation
AstonAficionado is infamous around these parts
Originally Posted by SonicKrack
Hey guys,
My conditioner has a cigarette lighter connection, so I presume you connect it to the cigarette lighter outlet within the cabin. In the owner's manual, however, it suggests that you open the trunk and access the small panel near the right corner of the trunk nearest you (over rear passenger tire). It appears that once you access that panel, there is a small socket you can plug into in the lower left corner. You first plug the conditioner into the socket, and then plug the AC plug into the wall outlet. To remove the conditioner, you disconnect in reverse order.
Having said that, it's a trickle charger intended to maintain a charge and may not be enough to revive a totally dead battery.
Old Feb 17, 2010 | 10:15 PM
SonicKrack's Avatar
Thanks AA,
I called a California dealership as they were still open and got some usefull information. The trunk did not want to open at all, so I had to jumpstart the car and let it run for a couple of minutes. Then I connected a battery charger for about 60 minutes so at least the battery tender could be somewhat functional. I also learned that the folding function of the mirrors is gone, I guess they will have to be reprogrammed. Thanks again for the great info !!!
adnanm3
Nov 22, 2023 02:43 AM
996_717
Jan 27, 2022 04:04 AM
kahala997s
Sep 15, 2015 05:15 PM
katyrow
Sep 7, 2015 10:17 AM
