Clutch replacement $10,000??
Old May 3, 2014 | 11:56 AM
  #31
Bleen's Avatar
Bleen is a glorious beacon of lightBleen is a glorious beacon of lightBleen is a glorious beacon of lightBleen is a glorious beacon of lightBleen is a glorious beacon of lightBleen is a glorious beacon of light
Originally Posted by karlfranz
^^^^ If you don't buy new, you are always at the mercy of how it was treated by the previous owner(s). It's no different for any other brand.
Hmmmm not really. a clutch going at 25k being the norm is rubbish and we all know it. We live with it cause the car is worth the inconvenience.
Old May 3, 2014 | 04:26 PM
  #32
zvez's Avatar
zvez is just really nicezvez is just really nicezvez is just really nicezvez is just really nice
I've set aside a $5k slush fund figuring if I don't need it for a clutch other things will probably arise.
Originally Posted by Ellipsis
FYI I'm a pretty new owner and these clutch stories scare the **** out of me. Car only has 5k miles on it, but from what i've read on these forums it can still fail depending on how it was treated earlier in it's life. All I keep on thinking about is when it was delivered the car smelt of burnt clutch from the truck driver
Old May 3, 2014 | 04:46 PM
  #33
karlfranz's Avatar
Not sure you got my point, otherwise I can't see how you can disagree. If your clutch went too soon, there are only two possible causes: 1) a manufacturing defect (usually rivets snap and the springs pop out; or 2) the (previous) owner abused it. There are literally hundreds of Astons with 40K, 50K and 60K+ miles on the original clutch.
Anyone can destroy the clutch on any car be it Aston or any other brand if they set their mind to it or are completely ignorant. I give you exhibit A:
Old May 3, 2014 | 04:48 PM
  #34
karlfranz's Avatar
FYI: A clutch job at my dealership costs only $3,500. This being done by Craig Newton who was chosen as the top Aston Martin tech in the USA.
Old May 3, 2014 | 04:53 PM
  #35
XWCGT's Avatar
XWCGT has a spectacular aura aboutXWCGT has a spectacular aura aboutXWCGT has a spectacular aura about
Not sure you got my point, otherwise I can't see how you can disagree. If your clutch went too soon, there are only possibilities 1) a manufacturing defect (usually rivets snap and the springs pop out; or 2) the (previous) owner abused it. There are literally hundreds of Astons with 40K, 50K and 60K+ miles on the original clutch.
That was funny! classic braindead!!
your point (and mine) are hopefully well made! these are not bad clutches... clutches go bad because people dont know how to drive them. these clutches are fine.... but when you ride the clutch, especially with softer clutch material, used on single disc clutches to reduce the grabbiness of the higher pressure , pressure plates, you can cook them and they will come apart.
if you drive the car right, dont burn the clutch, put it in neutral when approaching stop with pedal out (coast). not depress clutch pedal unless you are actually starting out or shifting, you will alllow the clutch to service you for many many years and lots of miles. 100k for sure
Old May 3, 2014 | 04:54 PM
  #36
XWCGT's Avatar
what is involved in the job... just drop the exhaust, torquue tube and then bell housing, and then remove the clutch and TOB ?
Old May 3, 2014 | 04:58 PM
  #37
Bleen's Avatar
Corvette Burnout Fail Destroys Clutch - YouTube
Hahaha awesome. What a tool.
The issue with the clutch might be true in manual cars but I don't know much you can do to protect the clutch in a SS, other than not reversion on hills or using crawl all the time.
Old May 3, 2014 | 05:01 PM
  #38
karlfranz's Avatar
Yet another reason why I don't like automated manuals.
Old May 3, 2014 | 05:08 PM
  #39
Bleen's Avatar
Well, I love a good automated manual system like BMW's DCT. After a month and so with a SS car I still can't get used to it and will probably be the reason I won't keep this car for more than a couple of years. Live and learn.
Old May 3, 2014 | 07:31 PM
  #40
karlfranz's Avatar
If you haven't had a chance to drive a Vantage with a manual gearbox, I suggest you give it a try. It's actually a really good feeling, solid shift.
Old May 4, 2014 | 03:53 AM
  #41
zvez's Avatar
nothing battery then a good manual gearbox............
Old May 5, 2014 | 11:32 AM
  #42
tko211's Avatar
tko211 is a jewel in the roughtko211 is a jewel in the roughtko211 is a jewel in the rough
I have been lucky so far... my AMV8 has 50k miles on the clock and the clutch still feels good. Another friend of mine has one with nearly 70K miles on the original clutch. Keeping my fingers crossed that I can get another 10-20k on mine!
Old May 5, 2014 | 07:58 PM
  #43
V12V's Avatar
V12V is infamous around these parts
I would like to see an Aston with a 100,000 mile clutch. I doubt one exists. A 100k clutch life is not a reasonable expectation in any car let alone an Aston.
Old May 5, 2014 | 09:37 PM
  #44
XWCGT's Avatar
if you know how to drive a clutch, yes its more than realistic. I drove my Porsche for 150,000 original miles with the same clutch. used parts of that clutch for a race car. ran the race car for 8 years and the clutch discs still had the serial numbers visible on the clutch disc surface. basically no wear and used for racing for 10 years and used 20,000 on the street.
most people just don't know how to drive a clutch . most all just don't
Old May 5, 2014 | 10:25 PM
  #45
karlfranz's Avatar
I have more than 93,000 miles on the original clutch of my daily driver Maxda MX-5
