royal purple oil
Old 10-25-2010, 04:28 AM
007 Vantage's Avatar
007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of
royal purple oil
Has anyone used rp in their vantage yet?
Old 10-29-2010, 09:48 AM
cshsia's Avatar
cshsia is on a distinguished road
the details for all the fluids are right there in the manual.
I went liquid moly. stayed with the factory specified weight though.
Old 11-01-2010, 09:04 AM
dicktahoe's Avatar
dicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of light
My dealer tells me that for '06-early '08, Aston is recommending changing to a lighter oil for the Transmission to make cold-shifting easier. Some owners have had trouble shifting, and if so there are replacement bushings for the shifting arms to correct this problem.
Old 11-04-2010, 08:41 AM
dicktahoe's Avatar
An update to my earlier post. My mechanic tells me that the bushing problem and thick transmission oil was only an issue with about 1000 vehicles in '06MY. All follow-on vehicles have the new bushigs and a lighter oil. The reason I am following this closely is that I had a major clutch failure on my '08MY, where the clutch came apart at about 9,000 miles. Here's my mechanics comment to me: "the clutch has been upgraded to stop the locating pins from parting causing this problem".
Old 11-05-2010, 07:50 AM
dicktahoe's Avatar
Symptoms were the clutch would not fully release so it was hard to shift gears. The worst indication was 1st gear, where on hard acelleration the clutch would not release at all until the engine and RPMs got back around 4,000, then I could force it out of gear. Also, in other gears especailly 3rd and 4th I often heard a slight grinding sound before the transmission would go into gear. The clutch was not fully releasing.
ECS Tuning - BMW
09-22-2015 07:49 AM
ECS Tuning - BMW
09-22-2015 07:31 AM
ECS Tuning - VW
09-02-2015 01:19 PM
Quick Reply: royal purple oil
