HELP! wealth engine problem!
Old Apr 4, 2011 | 09:08 AM
007 Vantage's Avatar
007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of
No, if you dynoed on a loading dyno the drivetrain loss is significantly higher (usually 3-5% more loss).
Without more information regarding what type of dyno you have its impossible to tell. I would bet its a loading dyno and not a dynojet type inertia dyno. Find out the type & brand of the dyno it is and report back to us, but from everything I see the car seems to be ok.
________
CherryBabe live
Old Apr 4, 2011 | 09:49 AM
vince_1972's Avatar
vince_1972 is just really nicevince_1972 is just really nicevince_1972 is just really nicevince_1972 is just really nice
I'll pass on the characteristics of the benches used tonight. You have to admit that, apparently, your car has the same problem as me.
I forwarded the power curve at the factory Aston at Gaydon and the ratios. It's so disturbing and incomprehensible that they will send me a specialist, direct from the factory, yet this month. I'll keep you posted if you wish.
Old Apr 4, 2011 | 11:11 AM
Well my car is literally in process of being tuned ... should fine out shortly. However from all the dynoes I have seen they are all between 290 for loading dynoes to 320 for dynojets. If they do so.ething for you let us know
________
The Sanctuary of Truth Pattaya
Old Apr 4, 2011 | 12:39 PM
vince_1972's Avatar
no problem
For both bench of power used:
-Bosch FLA 206 (bench official Swiss approval for new homologations, more than 800 tests per year cars, approve by the state)
-Rotronics of 2009 (bench of preparer Dijon Auto Tuning which only preparations engines, including the race)
tropicatango
Jun 8, 2025 01:00 PM
gulf gt
Aug 27, 2015 10:27 AM
elite1
Aug 26, 2015 09:22 PM
Yotam Refael
Cayenne
Aug 18, 2015 03:03 PM
