Clear rear lights + N420 carbon diffuser installation (how-to)
Old Jan 12, 2012 | 09:50 AM
Jarod's Avatar
Jarod has a spectacular aura aboutJarod has a spectacular aura about
Originally Posted by brumma
Hey Jarod, where did you have your diffuser installed? I am looking to do the same and am wondering if I need to take it to the dealer or if I can have an independent do it. Did the dealer give you any trouble about installing it since you didn't purchase it from them? If you don't mind my asking, how much did they charge for the installation?
Cheers,
brumma
Hi brumma,
I had it installed at a local garage specialized on this kind of stuff. Though it was not an AM dealer, the owner was the previous supervisor of the AM garage. Hi didn't mind to install the parts even I had not purchased at his shop. For the installation I paid 1.100 USD for both, the lights and the diffuser.
Cheers, J
Old Jan 15, 2012 | 11:02 AM
RCAMV8's Avatar
RCAMV8 is infamous around these parts
Hello Jarod, love the N420 diffuser!! Do you have any other pics which show more of the rear? I'm looking to do the clear lights, sills, and diffuser this summer. Thanks
RC
Old Jan 18, 2012 | 06:44 PM
VanessaDF88's Avatar
VanessaDF88 is infamous around these parts
How much were the tail lights??
Old Aug 3, 2013 | 08:07 AM
Vergis's Avatar
Vergis has a spectacular aura aboutVergis has a spectacular aura aboutVergis has a spectacular aura about
How long would you allow for this job???
Originally Posted by AMFixer
The best part is trying to fit the $%^ parking aid sensors, sometimes they just dont want to play.
Yes bumper does have to come off. There are a few screws behind the bumper that you need to get to.
Bumper removalsee if I remember)
1. Remove rear wheels
2. Remove fender liners, or move at least the portion that attaches to the rear bumper.
3. There are two bolts that attach the bumper to the fender. Two on each side of the bumper. So four total.
4. Now into trunk. Remove carpet on the sides of the trunk. Here you will see 3 large nuts that hold in tail lamps. So a total of 6 for the tail lamps, 3 each side. Sometimes clips hold in the carpet so get can be tough to remove.
5. Remove tail lamps being careful not to scratch the paint, and watch for the connectors. There is a red tab that slides away from the black part of the connector and the connector will come out of the tail lamp.
6. Now there are two screw on each side for the bumper. One will be where the fender and bumper meet. The other is right under the tail lamp.
7. Check also inside the trunk, where the carpet was removed sometimes there is a bolt in here to. Either an 8mm or a 30torx bolt. It attaches the side of the bumper to the car.
8. Now under the car. You may or may not need to remove the rear undertray. Where the exhaust finishers are, the a two black 30torx bolts that attaches the exhaust finisher to the metal bumper. So again two per side a total of four.
9. Then there are 3 connectors two on the passenger side and one on the driver. If I remember right the driver side may not come out, so once you get the bumper loose you may need to disconnect the harness from the bumper to get it all the way out.
10. Also be careful right above the plate frame the is a large piece of heavy duty velcro. Yes velcro, just pull up easy and it should come off.
Should be able to figure out the carbon diffuser from there. Also the part of the tail lamps, should be easy from here to.
Old Aug 3, 2013 | 09:05 AM
AMFixer's Avatar
AMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to all
If you have never removed a bumper and are doing it in your garage. I would expect it to take a full weekend. I would charge an hour for both lamps, if that's all I was doing. If I was doing the diffuser I would charge 3-4 hours, that would include the rear lamps if they were getting replaced.
Old Aug 4, 2013 | 11:03 AM
Vergis's Avatar
Cheers. Will give it a go this week.
Old Sep 12, 2019 | 03:59 PM
Dinomd's Avatar
Dinomd is infamous around these parts
I realize this is an old post, but does anyone know how the rear Parking Sensors come apart? Does the aluminum ring on the outside pry off or screw off???
Dino
COBB Tuning
Jan 1, 2025 09:02 AM
alevine
Nov 4, 2015 10:05 AM
gulf gt
Aug 27, 2015 10:27 AM
