New Vantage clutch bedding in question?
Old Dec 30, 2011 | 07:29 AM
Vergis's Avatar
Vergis has a spectacular aura aboutVergis has a spectacular aura aboutVergis has a spectacular aura about
Had a new clutch, slave plate and release bearing put it.
Everything works fine.
However the biting point when the clutch engages is a bit sharp in 1st and 2nd gear. 3rd gear + no problem.
Is this typical? Does it need a fair few miles on the car. So far I have done maybe 250 miles. I have never had a high performance stick shift car and a new clutch put it hence the question.
Also the clutch biting point is about half way up the pedal. Is it possible to adjust it so its slightly lower down. It feel a bit springy so far up.
Its strange really because on the old clutch the biting point probably had more travel on the pedal so the springiness wasnt an issue. ( if I can call it that ) .
Old Dec 30, 2011 | 09:29 AM
AMFixer's Avatar
AMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to all
There really is no adjustment of the clutch pedal travel. The only thing I can think, is bleeding the clutch. This would require a lift. I would hope after 250 miles it would have broke in a bit.
Old Dec 30, 2011 | 09:47 AM
stanger011's Avatar
stanger011 is infamous around these parts
08 v8v SS question?
Originally Posted by AMFixer
The really is no adjustment of the clutch pedal travel. The only thing I can think, is bleeding the clutch. This would require a lift. I would hope after 250 miles it would have broke in a bit.
Can you help, Ive had an 07 vantage manual, looking at buying an 08 vantage Sportshift.. 14k miles has a brand new clutch put in it b/c a bushing went bad in the old. Are there alot of issues with the sport shift, or does anyone have any opinions on the reliability? thanks!
Old Dec 30, 2011 | 09:52 AM
AMFixer's Avatar
There was some issues with clutches on SS, but the newer clutches are working ok. The reliability is the same compared to the '07. I would suggest driving a SS first if you have not already, you may not like the way it shifts.
Old Dec 31, 2011 | 03:16 AM
Vergis's Avatar
Admittidly the 250 miles are mainly motorway. I think some street driving and off the lights driving will help
COBB Tuning
Jan 1, 2025 09:02 AM
Jul 29, 2019 11:13 AM
Marcos AMV8
Dec 18, 2015 06:03 AM
