Rough idle
Old Apr 17, 2012 | 05:52 PM
Racer_X's Avatar
Racer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud of
Rough idle
Started up my car this morning to move it for a detail and the engine idled rough, as if the timing were off. I didn't think much of it at the time. When I restarted the car tonight to move the car back, it idled rough again. In addition, I noticed the clock was spinning as if I had just changed the time using the user interface. The idle smoothed out after a few revs, but I'm wondering what could have caused this strange behavior. Has anyone observed anything like this with their car?
Old Apr 17, 2012 | 08:59 PM
Jay_Davis's Avatar
Jay_Davis has much to be proud ofJay_Davis has much to be proud ofJay_Davis has much to be proud ofJay_Davis has much to be proud ofJay_Davis has much to be proud ofJay_Davis has much to be proud ofJay_Davis has much to be proud ofJay_Davis has much to be proud ofJay_Davis has much to be proud ofJay_Davis has much to be proud of
Yes, I've seen the clock spin from time to time. It seems like this happens when you leave the car unlocked for a while. I suspect when you lock the car it leaves the analog clock powered but sometimes when it powers everything down after a certain amount of time with the doors unlocked it powers down the analog clock and then has to catch it up when you power it up again.
Of course, its tough to tell if the "proper" behavior is to power down the clock or to leave it powered on. But one of the two is a bug.
Old Apr 18, 2012 | 05:56 AM
Racer_X's Avatar
Ah, I did leave the car unlocked all day yesterday because my paint guy was working on the car. So, I guess that explains the clock spinning.
Still wonder about the idle though. When I started the car yesterday morning with the driver door open, the idle was so rough that it caused the door to vibrate to the extent that I could see it move. Almost like not all cylinders were firing.
Old Apr 18, 2012 | 01:38 PM
mikey k's Avatar
mikey k is a name known to allmikey k is a name known to allmikey k is a name known to allmikey k is a name known to allmikey k is a name known to allmikey k is a name known to all
I had both symptoms (plus a few others) when two cells died on my battery
agentsmurf
Cayenne 955/957
Oct 17, 2015 02:10 AM
007 Vantage
Oct 8, 2015 08:35 PM
freddiemac
Oct 7, 2015 11:05 AM
TOGWT
Detailing
Oct 1, 2015 07:59 AM
PelicanParts.com
911
Sep 28, 2015 04:26 PM
