Warning Message: Engine Coolant Level Low
Old May 21, 2012 | 01:46 AM
rynacd's Avatar
rynacd is infamous around these parts
The error message engine coolant level low has come on a couple times the past 5 times i've driven the vehicle. First time it came on for about a minute then went off. Today it went on for a few seconds and off again.
Should i take it to the dealer? i still have warranty on the vehicle for a couple more months. Should i be concerned or is this a faulty message since it turns off quickly? Any help would be appreciated. Thanks.
Old May 21, 2012 | 05:40 AM
Racer_X's Avatar
Racer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud of
Check the coolant level! It's just low and needs to filled back up. The light probably comes on and off because the level is right at the edge of where the sensor is.
Old May 21, 2012 | 09:37 AM
AMFixer's Avatar
AMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to all
Racer X is right. Check for any leaks too, the coolant reserviour likes to leak.
Old May 21, 2012 | 10:29 AM
rynacd's Avatar
Alright thanks!
Old May 21, 2012 | 08:25 PM
dicktahoe's Avatar
dicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of light
Add just a little Distilled Water--No coolant is necessary. A cup or less should do it.
COBB Tuning
Jan 1, 2025 09:02 AM
Armytrix_F1_Exhaust
Jul 7, 2019 11:31 PM
