Engine stalling problem fixed in my AMV8 !!!
Old Jun 22, 2012 | 12:01 AM
ewu64's Avatar
ewu64 is infamous around these parts
My 2007 AMV8 had the stalling problem. I seek the help of Stuart from RSC Tuning, and he suggested taking a visit to his friend "Max" who owns and operates his own shop specializing in all types of German, English, and Italian exotic cars.
So, Max first replaced the “purge hose” inside the fuel tank as suggested by AMfixer in another thread. It wasn’t gummy or torn but, he replaced it anyway with an internally braided, aviation quality, rubber hose that he special ordered. As Amfixer has pointed out in several other threads, a pin size hole in this hose can suck in gas and produce the stalling. However, after driving the car with the new hose installed, it stalled again.
One thing that I have always noticed is that the stalling mainly happened when the tank is half to full. The stalling seemed to disappear once the fuel tank was below half. So, I took the car back to Max and he suggested to change the “Roll Over Valves (ROVs)”, which are two: left and right inside the fuel tank, and change all related hoses going to these valves, just in case. And it’s been more than a month after these repairs, and no stalling whatsoever. I tested the car with the fuel tank full, half, almost empty; taking hard left/right turns, coasting to a stop in gear/out of gear, hard brakings, incline, declines, etc. It seems that the problem has been solved. I have put almost 900 miles since the repairs and no stalling; and my car used to stall pretty frequently. I have read somewhere, that Aston replaces the fuel tank to solve the problem, and from their labor/hour stand point, it makes sense. However, Max charged me, parts and labor, extremely cheap; specially, considering what he had to do.
This is not a DIY thing. The opening of the fuel tank thru the trunk is pretty small, and you have to work with mirrors inside the empty fuel tank to see what you are doing, as the valves are on top and to the sides of the fuel tank.
I hope this helps everybody that is suffering from the stalling in their AM cars.
It is pretty funny that Aston does not recognize this as an endemic problem in their cars. However, the solution they propose is to replace the entire fuel tank. But at the same time, they sell you all the parts that come inside of it… and they are pretty inexpensive parts!!!
Just in case, if any of you live in the Miami area, and want to contact Max Azael, his email is: azaelmotorsport@gmail.com
Old Jun 22, 2012 | 08:50 AM
Irish07@VelocityAP's Avatar
Congrats on the fix, don't believe the ROV's were the fault..but the hoses to them all and the purge, and even DMTL all have been know to cause this issue..
The tanks used to be replaced under warranty, now every part inside the tank is serviced..manly cause to replace a tank the whole rear sufbrame and transaxle is coming out to remove the tank..
tropicatango
Jun 8, 2025 01:00 PM
LiquidElephant
Aug 27, 2015 06:17 PM
gulf gt
Aug 27, 2015 10:27 AM
Sales@RSW
BMW //M
Aug 26, 2015 06:41 AM
Yotam Refael
Cayenne
Aug 18, 2015 03:03 PM
