Lumbar Support Not Working
Old Sep 10, 2012 | 01:31 PM
Vergis's Avatar
Vergis has a spectacular aura aboutVergis has a spectacular aura aboutVergis has a spectacular aura about
This is the button next to my seat by the heated seat button.
Whether I am in ignition switch 2 or car started it does not work.
I have looked up the fuse in the manual which states F85 in cabin. However the 25 amp fuse includes the seat adjustment. The seat adjustment works fine.
Has anyone had a similar problem. Is it worth taking the switch out and and checking connectors? I think that might be my next option???
Old Sep 16, 2012 | 07:37 AM
Vergis's Avatar
For anyone in the future that may have this problem I managed to fix it.
I prised out the lumber switch from both sides carfully and put the ignition on.
The switch started working. One of the connectors in the switch was faulty. Surprise surprise.
I uncliped the switch and where there was movement on one of the terminals I super glued it with a tiny drop on the plastic where it enters the switch.
Switch works fine. Not the best solution. New switch would be best but I never change lumber so for me it works and saves a some money on a new switch.
Old Sep 16, 2012 | 09:40 AM
DetomasoGTS74's Avatar
Thanks Vergis, my lumbar support has been out for some time. What did you use to pull the switch out?
Old Sep 16, 2012 | 09:58 AM
Vergis's Avatar
A very small flat head screwdriver. Edged one side then the other bit by bit.
Old Sep 16, 2012 | 07:36 PM
Thx, will try it next weekend
dkim12
Jan 21, 2021 04:00 PM
COBB Tuning
Mar 29, 2016 09:26 PM
pshep138
Sep 1, 2015 09:45 AM
Rumrunner
Charity Notices/Events
Aug 20, 2015 11:07 AM
