Vantage Seatbelt Strap
2 Attachment(s)
The factory magnets that hold the seatbelt strap in my V8VS (and my previous Vantage) are too weak to hold the leather strap secure. I found an inexpensive solution. By using two small doughnut shaped, nickel plated rare earth magnets (super strong), the straps stay in place. I used two on each seat. I used super glue to secure the bottom magnet to the factory magnet on the seat side. I did not glue the two magnets together, and I did not glue the strap side so that I can still release the strap if necessary. A set of 10 rare earth magnets cost about $15.
Thanks for an excellent, easy to implement suggestion to a nagging problem--I just added to your "Rep Power".
Thank you! I was just about to post about this issue. Where did you order the magnets?
Originally Posted by DoctorWill
(Post 3741650)
Thank you! This is such an annoying issue. How do you give rep power? Because you definitely earned it
(Post 3741650)
Yep, their magnet is useless!
Originally Posted by plastique999
(Post 3741816)
Will, on you brand new V12V? |
Interesting, because I've never had this problem. If the center raised part of one "half" of the magnet is seated in the center recessed part of the other "half," it has always held perfectly well.
I thought it was just my car until I saw this post the magnet doesn't stick so the latch is always open. I think I'll give the extra magnet a try!
(Post 3741828)
What's the deal w this strap thingy? Seats on the vantage are similar to the DB9/DBS is basic shape and so forth I thought, I don't ever recall seeing or using such a strap or magnets in my DB9 just pull the seatbelt and fasten like any other car...why didn't Aston just use a nice button instead of weaker magnets for the vantage?
Originally Posted by sunir
(Post 3741881)
Really, I have them on my V12V!
Originally Posted by groutguy
(Post 3741884)
No such strap on my V12V either! |
Rare earth magnets are a good idea, but is it necessary to superglue them in place? I lean towards easily reversible modifications.
Originally Posted by Racer_X
(Post 3741918)
Originally Posted by kba
(Post 3741802)
