Aston Martin DB9 transmission cooler hose leaking
Old Apr 21, 2013 | 12:53 PM
dan87951's Avatar
dan87951 is a name known to alldan87951 is a name known to alldan87951 is a name known to alldan87951 is a name known to alldan87951 is a name known to alldan87951 is a name known to all
As I was under the car doing the differential I noticed a small leak coming from my transmission cooler (up front). I know this is a very common problem for the early 05' DB9's and was told mine had the updated kit. Does anyone know the part#'s for the updated cooler and hose? I would like to check them. Irish?
Thanks guys!
Dan
Old Apr 21, 2013 | 09:10 PM
sunir's Avatar
Very common indeed for DB equipped w tt2 running gear.
Old Apr 23, 2013 | 12:28 PM
AMFixer's Avatar
AMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to all
Do you want the part number for the whole kit, or just the cooler and front hoses?
Old Apr 23, 2013 | 12:48 PM
dan87951's Avatar
Could you give both? Isn't the kit just the hose and cooler or is there more?
Old Apr 23, 2013 | 11:00 PM
AMFixer's Avatar
The kit comes with a new cooler, both front hoses, and the two longer hoses that run along the side of the engine, and hose clamps. From the rear of the engine back to the transmission, it's all steel tubes, no rubber.
Cooler--it looks like u can't get a cooler for early vins, just the kit only, but after vin A09784, 7G43-445396-AA, same cooler in the kit, so should work for early vins
Front hose#1(inlet) 7G43-7F120-BA
Front hose#2 (outlet) 7G43-7F120-AA
Side hose#1(outlet) 9G43-7W093-BA
Side hose#2 (inlet) 7G43-7W093-AA
Kit with cooler 4G43-31-10938
Kit without cooler 4G43-31-11060
Old Apr 24, 2013 | 03:47 PM
dan87951's Avatar
Just gave you a rep bump! Thanks for the info man, you're a life saver. By chance you wouldn't happen to know what kind of black goop/sealant they use around the front defrost vents to keep them from rattling?
Old Apr 24, 2013 | 03:51 PM
AMFixer's Avatar
I don't think we do that anymore. The new defrost vents screw into the upper dash.
Old Apr 24, 2013 | 03:54 PM
dan87951's Avatar
I don't think the 05 DB9 defrost vents are screwed in? Mine appear to be just snapped in with that black goop around some of the edges.
Old Apr 24, 2013 | 04:07 PM
AMFixer's Avatar
I know they updated to the screw in type.
spinecho
Sep 6, 2015 08:35 PM
zuman
Sep 3, 2015 08:27 AM
m_motorsport
Sep 2, 2015 12:53 PM
manipou
Sep 2, 2015 12:42 PM
