Problem resetting "Time for Regular Service" message
I just finished changing my oil and I'm having problems resetting my service reminder message. I followed the steps AMFixer posted a while back:
DB9 and V8 can be done without the AMDS. I have yet to find one that this doesnt work on. 1. Shut all doors 2. With key in position 1 hold the t1/t2 button in the center stack. 3. Turn key to position 2 still holding the t1/t2 button. 4. Watch for the yellow triangle to start to flash at least three times, let go of t1/t2 button after three flashes. Should hear a audible beep. 5. Turn key on making sure service light is off Might take you a couple of tries to get it. Also, according to some on the DIY Oil Change thread, you have to pour in the first 7L of oil, start the engine for a few seconds, and then fill the remaining oil. I can verify that this is absolutely not the case. If you fill the oil slowly there is no problem pouring in all 10.4 liters at once. I even checked using the dipstick after pouring every liter over 7, just to make sure. I don't know what forum member, Blayne, did that caused him to overflow and spill the last quart, but this should not happen. |
Try holding the T1/T2 button the entire time. Before you even touch the key press and hold the T1/T2 button. then do the process.
^^^^ Thanks for the reply. I tried it about 30 more times and I never heard the audible beep like I did last year. I let the triangle flash 3 times, 4 times and depending on how quickly you let go of t1/t2 you often get an additional quick flash. I also noticed that you can get the triangle to flash if you just hold it down while the key is in position 1.
Either way, never heard a beep, but surprisingly, when I moved the key to position 3, the message was gone. So now I don't have to worry about this again for another year. Thanks again. |
How does key position relate to a 2016 with that black box that gets inserted, There is more than one level of insertion. Thanks, all
Check out this link:
https://www.6speedonline.com/forums/...-2015-db9.html If you want to get your digital speedometer back, press the "read" button after starting. |
My 2016 v8 Vantage 6 speed does not seem to have a "read" button at least not that I can find and the center console pictures in posts are foreign to me. However the glare problem in sunny southern Cal. makes most of the lettering unreadable most of the time anyway.
The button on the end of the turn signal also cycles thru the digital display options, at least on my 2010. 2016's have the redesigned waterfall, I have no idea how any of that works.
Thank you!
I was able to turn mine off thanks to this thread.
Thanks! |
On '16 and '17, the read button is the one with the i (for information). Center, bottom right of the waterfall. T1/T2 still the same.
Procedures are the same for resetting '12 to '15 with the crystal key. |
