Wheel and tire , something rattling around
Even took the tire off to patch it with a radial plug and found the rattle to be inside the tire. is the pressure sensor loose or did it break when I was drving down the road at very low pressure? can it be tightened up by the external nut on the valve stem? something is loose and it rattles on the rim, that sounds like im dragging some metal parts behind me on a string.
If the external nut was loose on the outside, you would be able to move the valve around or push it inwards slightly...
Technical Director
Christopher Edgett
214 Maple Ave.
Oliver, B.C
Canada V0H 1T9
Office: (1)250-485-5126
Email: Tuning@VelocityAP.com
www.velocityap.com
Technical Director
Christopher Edgett
214 Maple Ave.
Oliver, B.C
Canada V0H 1T9
www.velocityap.com
it turned out to be a handle of a plyers that entered the tire, was not quite all the way in for sometime and then it fell in the tire, causing a leak, with no visible nail or cause. pulled the tire off and there it was. a metal handle of a pylers. weird!!!
turbotuner20v
Sep 11, 2015 12:02 PM
Sterlingc1975
Aug 22, 2015 02:30 PM
