I have never run into this issue but it sounds like you are on the right path. If it only happens while moving, during hard left turn then it should be a related solution. Check for some type of debris that would connect with the wheel or rotor during a turn (maybe stuck in the A-Arms).
It can be difficult to tell if a noise is coming from the front or back while in the car but the noise might be related to the differential, only occurring when rear tire rotation is at a maximum difference. In this scenario the temperature of the diff gear may be the 'random' factor. That was just my observation from the information I read. I certainly don't mean to get you worried about nothing... It's probably just a rock in the rotor. |
Originally Posted by rbobby
(Post 4028908)
I had it happen once early on. I thought I broke something serious after a hard turn. It probably was a piece of road debris. I heard something metallic fall out onto the road and the scraping noise was gone. Car was fine since.
I have had the same experience on every vantage I have had. Just happened on the V12. Stopped and looked and nothing. Must be the rock theory!
I picked up a stone in mine just shortly after I got it. It cut a lovely deep groove in the rim where the stone was trapped between the brake caliper and the inside of the rim. It also made a serious racket when doing its job !!!!
This thread has become a huge source of relief for me!
As Dealers are known to say, "TADTS" (they all do that sir). ;)
