DB9 Performance Air Filter
Im trying to decide if i should upgrade the factory aston air filter with a performance air filter from rsc. I wanted to see if anyone on here has made this upgrade and have noticed any gains.
Originally Posted by jyu12
(Post 4037641)
I'm running RSC filters on my DB9 as well. My original filters were very dirty (thank god not oily!!!) so I can feel a little bit of improvement with the RSC filters.
Originally Posted by hph
(Post 4039194)
Thanks in advance. |
4 Attachment(s)
Originally Posted by 4leafcloverz
(Post 4093843)
Where are the filters located? I just bought a pair myself and am trying to figure out if I need to remove the underpanel or go through the wheel arch.
DB9 air filters
It is not necessary to remove the front undertray to change the DB9 air filters if you are prepared to drill a couple of 20mm holes in the undertray to allow access to the 2 screws hidden behind it. It will also be necessary to have a long flexidrive with an 8mm socket. There are 2 difficult screws on each air filter box. One can be accessed through the undertray louvres, but the front most one needs a new access hole in the tray. Once drilled any future filter replacements are dead easy unless you are a big fan of undertray removal.
Originally Posted by Organeer
(Post 4446421)
