Vantage Jaguar Engine Swop for more Power
Old May 9, 2014 | 11:40 AM
telum01's Avatar
Originally Posted by frankgtb
fyi alot of aftermarket superchargers are basically turbos (not the roots type) that run off the drive belt off the front of the engine (where v8v seems to have alot of room )and therefore no need for tampering/moding that perfect body
Centrifugal superchargers (the ones you're describing) and other aftermarket options aren't in question. That's been done. The original question was about dropping in a Jag's supercharged engine, which has a roots-type supercharger that sits on top of the engine. I also mentioned the oil pan, which *might* be a normal wet-sump on the Jag engine rather than a dry-sump like we have in our V8Vs (I say "might" because I have no idea which it is). If it is wet sump, the engine will have to be raised in the engine bay to give ground clearance for the larger oil pan, also increasing the height requirements of the engine in the car.
Old May 9, 2014 | 10:13 PM
1analguy's Avatar
1analguy is infamous around these parts
Originally Posted by anton28
I vote LS7 with T6060 6speed. Boom!
I know, right?!?
Jul 29, 2019 11:13 AM
Jun 10, 2017 07:45 PM
Ferrari
Aug 24, 2015 04:35 PM
DerekShiekhi
Other British Cars
Aug 19, 2015 05:25 PM
ECS Tuning - VW
Aug 19, 2015 11:08 AM
