Chirp...chirp...chirp...as the wheel turns...
Old May 14, 2014 | 08:36 AM
WearyMicrobe's Avatar
WearyMicrobe has a reputation beyond reputeWearyMicrobe has a reputation beyond reputeWearyMicrobe has a reputation beyond reputeWearyMicrobe has a reputation beyond reputeWearyMicrobe has a reputation beyond reputeWearyMicrobe has a reputation beyond reputeWearyMicrobe has a reputation beyond reputeWearyMicrobe has a reputation beyond reputeWearyMicrobe has a reputation beyond reputeWearyMicrobe has a reputation beyond reputeWearyMicrobe has a reputation beyond repute
Originally Posted by XJRS Owner
They should not wear at all, unless you forget to release them before driving off, which is easy to do with this type of lever that falls back to the floor.
Its a known issue on the Brembo's that they burn out the parking brake pad for some reason. Happens on the viper's with a similar setup all the time.
On most Brembo packages there is a small metal shield on the rear brakes that covers the pad and another on the parking brake. Though they get removed a lot by owners.
Old May 14, 2014 | 08:42 AM
XJRS Owner's Avatar
Slightly less than cast iron discs. CCM: 0 to 7 ppm/K Cast iron: about 6 ppm/F or 10 ppm/K
Old May 15, 2014 | 03:38 AM
rscultho's Avatar
rscultho is infamous around these parts
This morning was wet in the ATL. I did not hear the sound/chirp.
Old Sep 23, 2015 | 04:20 AM
geh065's Avatar
5 Year Member
geh065 is a jewel in the roughgeh065 is a jewel in the roughgeh065 is a jewel in the rough
Sorry to drag up an old thread. I've recently bought a 2005 DB9 and during the test drive I thought I heard these squeals/chirps but living in a city I wasn't sure if it was the car or an outside noise. I asked the owner and he said he heard nothing. I didn't hear it for the rest of the very short test drive I did.
Before I took ownership of the car, the dealer said the brake pads/discs all needed replacing including the handbrake. I finally took possession of the car and notice that the squeak I heard during the test drive is still there. All the brakes have been replaced so any other ideas what it could be? Surely the dealer can't have installed the brakes badly to cause the squeal to continue?
Old Sep 23, 2015 | 05:59 PM
Montana107's Avatar
Montana107 is infamous around these parts
I have the same noise from I believe the rear brakes... New pads, rotors and inspected parking brake pads... Might take off pads and file edges at an angle to see if that helps or...
We can stay full in the gas off the line and drift it around parking lots so no one will hear your exotic sound like a junker... JK
I too am interested in a resolution or any ideas
Thanks!
Old Sep 26, 2015 | 05:35 AM
Timothy Ward's Avatar
Timothy Ward is infamous around these parts
Mine has done the same. I found it was the handbrake, the metal retaining pads that clip on to the pins and pads.Tim
Old Sep 28, 2015 | 11:08 PM
rob4wellness's Avatar
rob4wellness is infamous around these parts
I just bought a 2002 Vanquish recently. When I started it today, after battery discharge, I hear a high-pitched chirp (from rearend it seems). It chirps with ignition 'on' even...I don't need to be driving the car or have it running. Anybody have any idea?
Old Sep 29, 2015 | 09:23 PM
Does it chirp or squeak? Does it do it when not moving? Mine does.
Old Oct 1, 2015 | 06:02 PM
geh065's Avatar
5 Year Member
I try to run the engine at idle for a few minutes before driving and during that time it makes all sorts of whines and squeals but I am referring to when driving it makes a chirping sound - literally sounds like some small birds are nesting in the car!
Old Oct 10, 2015 | 06:27 PM
I try to run the engine at idle for a few minutes...
Been away from this thread. Did you ever find the problem? If not, does it change in frequency with various speeds? Have you tried going to a quiet, safe street where you can drive and then shut off the car to coast (be careful not turn the key back to off and lock the steering wheel)...maybe 15-20 mph...slow enough to stop easy w/o power brakes. Im curious if it still does it with engine off and moving (or hook up the tow eye and tow it down the street). Maybe with engine off you can better isolate if the source is at the front, mid, or rear area.
Old Oct 10, 2015 | 06:30 PM
Also, I wonder if the dealer used that disc brake 'quiet' spray or paste that reduces/prevents disc brake squeal. If not, that's a probably source.
Old Oct 10, 2015 | 06:35 PM
Prefurbia's Avatar
Prefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond repute
My 2007 chirped all the time... My 09 and 15 - no chirp
Old Oct 10, 2015 | 07:08 PM
Did you ever find out what the chirp was on your '07? Brakes?
Old Oct 10, 2015 | 08:21 PM
Prefurbia's Avatar
Something coming from the engine
Zero911
Aug 24, 2015 06:51 PM
Aug 21, 2015 09:56 AM
ModBargains
Aug 20, 2015 12:28 PM
PelicanParts.com
930 Turbo Vendor Classifieds
Aug 18, 2015 04:01 PM
