I drive, therefore I am
Old Aug 3, 2014 | 08:47 PM
terminal_ac's Avatar
terminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to behold
Is it normal to see a red flash on the dash when going through the gears really hard, i.e., I believe the red "reverse" indicator comes on when hitting "redline" in my car (Vantage V8S).
In the alternative, have I found an electrical/software flaw?
Insight?
Old Aug 3, 2014 | 09:18 PM
rbobby's Avatar
rbobby is infamous around these parts
Are you referring to the shift indicators? In a manual, it looks like horizontal bars. In a sportshift, gear number flashes red. All in the manual.
Old Aug 4, 2014 | 02:49 AM
zvez's Avatar
zvez is just really nicezvez is just really nicezvez is just really nicezvez is just really nice
shows you're at the upper limit of the rev range.
Insight?
Old Aug 4, 2014 | 08:27 AM
Thanks for this.... The owner's manual is a bit "much". I really just use it as a reference. I've seen that indicator come up a few times (i.e., twice), but I've never been able to clearly discern what it was since I'm more concerned with what's happening on the road. So it merely appears as a flash!
Old Aug 4, 2014 | 10:26 AM
karlfranz's Avatar
rtfm!
Old Aug 4, 2014 | 11:32 AM
Originally Posted by karlfranz
rtfm!
I read it on a need to know basis!
Old Aug 4, 2014 | 11:52 AM
karlfranz's Avatar
Hmm. Sounds like you "needed to know" at the beginning of this thread.
Old Aug 4, 2014 | 05:33 PM
JuanP's Avatar
JuanP is infamous around these parts
It would be nice if there was a more pronounced shift indicator (ex: BMW shift lights). Trying to see the gear indicator turn red while accelerating can be challenging - especially with the top down.
Old Aug 4, 2014 | 07:12 PM
FatFrank's Avatar
FatFrank has a spectacular aura aboutFatFrank has a spectacular aura about
+1 LOL
I will read mine one day.... , but I swear it can be quicker to post...
Old Aug 5, 2014 | 10:18 AM
Originally Posted by FatFrank
+1 LOL
+2 LOL
Such wonderful people here who are so willing to help out!
Old Aug 5, 2014 | 10:52 AM
Fubar's Avatar
Fubar has a spectacular aura aboutFubar has a spectacular aura about
Owners manual is fairly useless. It doesn't even include information on the fuse box under the passenger footwell. - Crazy!
Additional, let me suggest that you read some of the FINE print (as there is a considerable amount). Aston Martin requires its owners to check their oil every 10 days or two tanks of gas. If you do not, the warranty is voided. Of course the question would be, how do they know if you did or didn't... answer: if the oil is low, then you didn't.
Old Aug 5, 2014 | 11:05 AM
Caught that! I'll be headed home to check the fluid levels because I haven't looked at em since I bought the car. I tried looking for the traditinoal "dip stick", but just figured out this car doesn't have one. This is quite an adventure, might I add.
Old Aug 5, 2014 | 06:31 PM
zvez's Avatar
be sure to do proper technique for checking oil, start car run for 30 seconds, let stand for 30 seconds and unscrew the oil tank lid (dipstick attached), wipe clean, screw on again and unscrew, check level.
Old Aug 6, 2014 | 01:02 AM
mikey k's Avatar
mikey k is a name known to allmikey k is a name known to allmikey k is a name known to allmikey k is a name known to allmikey k is a name known to allmikey k is a name known to all
From cold as well
This process only applies on the V8 because of it's not so "dry sump" system
Old Aug 6, 2014 | 08:48 AM
Piece of cake! Checked all fluid levels, and everything is where it should be.
