Could use a little help!!!
Old Jan 19, 2015 | 05:27 PM
EZ Cookin's Avatar
EZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud of
My first lesson learned and now I have an issue that I could use help with. These batteries don't last long. I was over a friends house showing him my new car at night. Without realizing it might be a problem I put the top down and then back up and showed him the car with lights on without it running. When I went to leave the battery did not have enough juice to start. He grabbed his jumper box and it quickly started but gave me every code from alarm system failure, to traction control dissabled etc, etc... After putting the car on my trickle charger the warnings still persist. I tried taking the terminals off the battery for a period of time and after reassembly now the car won't start and my start button is bright red and the engine light is illuminated with a loud noise persisting from the engine area even with key removed. I had to remove the battery terminals again to stop the noise.
Tell me there is an easy fix.
Old Jan 20, 2015 | 02:26 PM
EZ Cookin's Avatar
It case anyone wants to know I found the problem was my battery. I replaced it and all the fault codes went away and the car is now running properly.
Old Jan 20, 2015 | 07:55 PM
Irish07@VelocityAP's Avatar
I would of guessed the battery was weak or faulty from the beginning, before even showing your friend the car.. I weak/faulty battery can start and run a car fine... Just it won't hold charge long enough under load
Good job though on replacing it..although if it's a pre 2009.5 model you might want to search for Misfire Corrections and how to set them..
Technical Director
Christopher Edgett
214 Maple Ave.
Oliver, B.C
Canada V0H 1T9
Office: (1)250-485-5126
Email: Tuning@VelocityAP.com
www.velocityap.com
