Installing clear tail lamps
Old Mar 17, 2015 | 06:23 PM
rohnin's Avatar
rohnin is infamous around these parts
Someone told me that clear tails needed to be reprogrammed when installing, is that true? I have a set of new OEM clear tails I want to install on my 07 Vantage, and if an independent shop can do it other than the dealer (who would have access to any software), it would be great!
Old Mar 17, 2015 | 07:02 PM
midwestamv8's Avatar
midwestamv8 has much to be proud ofmidwestamv8 has much to be proud ofmidwestamv8 has much to be proud ofmidwestamv8 has much to be proud ofmidwestamv8 has much to be proud ofmidwestamv8 has much to be proud ofmidwestamv8 has much to be proud ofmidwestamv8 has much to be proud of
The ECU needs to be reprogrammed in order for the dash to let you know if a bulb goes out. Clear tails will still work fine on an 07 without the reprogramming, but you won't know if a bulb is out - that's it. At least, as far as I know.
You'll need to decide if it's worth it or not to update the software. My dealer had to charge for the software since they said AM made them purchase it from them directly and it was tied to my VIN. It was around $90 for the software if I remember correctly. I had them do it when they did the tails and the diffuser on my 07.
Old Mar 17, 2015 | 07:56 PM
yvr's Avatar
yvr
yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !
I seem to recall something about 4-way flashers possibly being affected too. Maybe try those before deciding to update software?
Old Mar 19, 2015 | 09:05 AM
rohnin's Avatar
Thanks for the info I wonder if it's possible to install the lights elsewhere and then bring to the dealer for the reprogramming later? How much should it cost total? Or is it better to just do it at the dealer in case anything goes wrong?
COBB Tuning
Jan 1, 2025 09:02 AM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
gulf gt
Aug 27, 2015 10:27 AM
